Brake pads for Spec...
[Closed] Brake pads for Specialized Crave Comp 2015
3 Users
I've got a Specialized Crave Comp 2015 and the brake pads have worn out after just 45 miles down to the metal which is appalling.
I don't know what type of brake pads to order that are compatible with this bike. I've fitted brake pads on my other bike, I just don't know what type to order for this one. On the specs it says the brakes are "Shimano Deore, hydraulic disc, dual piston, resin pads". Anyone know which pads I need please?
Posted : 28/12/2015 4:08 pm
Have a look at the identification chart here:
[url= http://www.superstarcomponents.com/en/organic-disc-brake-pads.htm ]Superstar[/url]
At a guess it'll be s1 or s2.
Posted : 28/12/2015 4:18 pm
It says S1/S2/S3 are all Shimano Deore. The only clue on the bike specs for my bike is that the brakes are Shimano Deore. How can I tell which one it's supposed to be?
Posted : 28/12/2015 4:29 pm
Remove a pad and see what shape matches on the chart I guess!
Posted : 28/12/2015 4:36 pm
The brake pads look closest to an S2 to me
Posted : 28/12/2015 4:43 pm
The website only gives the option for Organic for the S2 pads. Is organic going to last long? I don't want a repeat of the original pads which were a waste of time and worn out after such as short distance, it was beyond appalling
Posted : 28/12/2015 4:51 pm
If you've gone off the link above that's because I'd already pre selected organic.
If you go here [url= http://www.superstarcomponents.com/en/shop/mountain/mountain-braking/mountain-disc-brake-pads/ ]Superstar[/url] you can select organic, kevlar or sintered.
Organic generally have a shorter life but better feel, I find.
But not 45 miles to metal, they were either faulty from the start or it was and incredibly tough/muddy/gritty ride!
Posted : 28/12/2015 5:31 pm
Sounds like the pads hadn't been bedded in before the first ride.
Plus in winter I generally avoid organic pads for exactly the reasons you've found.
I'd recommend sintered pads in winter / cruddy conditions. You get practically the same braking power, but less wear than organic.
Posted : 28/12/2015 5:57 pm
Depends on riding conditions really.. I run ss organic pads regardless, I generally get about 700km out of them and I ride in mud and rain a lot.
Posted : 28/12/2015 7:49 pm
Thanks, I'll give them a try.
On my other mountain bike it has done over 2000 miles and I've only changed the brake pads twice (one of those being very recent). I couldn't believe it when the pads had gone on the Crave when it had only done 45 miles. It was in muddy weather though and I had forgot to put a front mud guard on it, but you'd still never expect that.
Posted : 28/12/2015 9:26 pm
