Brake line to short...
[Closed] Brake line to short. Advice please.
3 Users
1. I have a have another set of brake with a longer one. Can you swap an old one over? If so how hard is it?
2. To lbs to fit new one, any idea on cost? For standard one.
Posted : 30/08/2014 1:06 pm
If the brakes are the same then swapping should be easy, if not you will need fittings and a new length of hose + full bleed.
Posted : 30/08/2014 1:19 pm
Cheers I will check the fillings
Posted : 30/08/2014 8:53 pm
Insert another o.
Posted : 31/08/2014 7:57 am
