Is it possible to narrow the distance between bars and lever on a set of hydraulic brakes when the lever adjuster is adjusted as far as possible but they’re still too far from the bars?
What brakes
Theres loads of room. Ive got long fingers and they’re still too far out. Theyre Trktro ones i think.
Sounds a bit odd that brake levers set to minimum reach are too far away for someone with long fingers.
What brakes and what bars are you using?
Pics would help of the setup you've got currently.
Carefully bend the levers
How low are your levers positioned?
What you have described doesn't compute in my simple brain and I can only think your levers are pointing downwards vertically?
Heat and bend the levers. Or try and crash in the exact right way.
Does sound weird though, very few brakes don't have enough adjustability for stubby fingered people never mind long fingered elfs.
too much fluid (pistons weren’t pushed back) when they were bled?
This is the only thing I can think of that would cause the problem.
Are we talking about MTB bars here, or road/Gravel?
