Brake lever as Reve...
[Closed] Brake lever as Reverb remote?
7 Users
Random musings really..
I'm probably going to be replacing my Thomson Dropper when it comes back/is replaced under warranty and I'm probably going to be trying the Reverb next although I don't really like the remote.
Thomson failed twice, LEV failed twice...
So, could a brake lever work as a remote lever for a Reverb?
I'm thinking something like an old Hope Mono lever where there's enough material in the handlebar clamp to attach a new mount to reduce the distance from the lever to the bars, mount it backwards and make a new lever to make it easier to reach..
Could it work or am I mad? The Reverb just pushes a bit of fluid, like a brake lever, doesn't it?
Posted : 21/03/2016 12:30 pm
It's a good idea. Try a magura lever or shimano lever though as hope seals will swell in mineral oil.
Posted : 21/03/2016 12:34 pm
How about one of these instead?
Yep, seen the Novyparts one. Looks good but pretty expensive for what it is.
Think I'll see if I can pick up an old lever to pull apart and have a look at.
Posted : 21/03/2016 12:36 pm
In principle, it *might* work, but there's a little bit more to it than just "pushing a bit of fluid". You need to know how much fluid you're pushing and/or how much fluid you need to push. Push too much fluid - you'll overpressurise the system and hopefully just blow a few seals. Push not enough fluid - you won't operate the system.
Posted : 21/03/2016 12:37 pm
Why did bloody SRAM not redesign the stupid button to look and work like that Novy one?.
Posted : 21/03/2016 12:40 pm
Because back in the day we had freakish things called front shifters which they needed to work around?
Posted : 21/03/2016 12:54 pm
They have done. It's going to be available first on the new enduro specific Reverb that's due in 2017 model launch.
Posted : 21/03/2016 1:05 pm
Dont forget to consider the fluid type. The lever seals may not be compatible with the reverb fluid.
Posted : 21/03/2016 1:08 pm
