Brake caliper adapt...
[Closed] Brake caliper adapter... just checking.
3 Users
Current bike has 180mm rear post mount, ie. 180 is the smallest rotor it will take, which it does WITHOUT adapter. If I want to run a 203mm rotor I assume I need a post to post adapter normally used to run a 180mm rotor in place of a 160mm rotor,
ie. something like this
http://www.uberbikecomponents.com/view-product/Uberbike-Front-Post-to-Post-180mm-Disc-Brake-Mount-adapter-Colour-Options
rather than a 203mm adapter, like this
http://www.uberbikecomponents.com/view-product/Uberbike-Front-Post-to-Post-203mm-Disc-Brake-Mount-adapter-Colour-Options
since I am effectively only going up one size???
Is this correct? Or is there another type of adapter I am missing.
Posted : 30/10/2015 4:12 pm
What I did find with some IS to post adapters (shimano in particular) was that they were sold as front or rear not both. I am not sure if they were actually different shapes. My suspicion is just labelled differently to reflect that a rear 160 adapter was in effect a front 180.
Posted : 30/10/2015 4:31 pm
Sorry I don't think that necessarily helps.
Posted : 30/10/2015 4:32 pm
I guess what I am asking is whether a post to post 160-180mm adapter is essentially the same as a post to post 180-200mm adapter. Pretty sure it doesn't matter whether it is front or rear.
Thinking about it I am pretty sure my Pikes on the front will take 180mm minimum rotor and I had to use a 160-180 adapter on them to fit the 200mm disk. So I think that answers my own question. 🙂
Posted : 30/10/2015 4:38 pm
yeah post to post should be either just front or back and think of them as a +20mm.
The shimano IS to post are actually different front and rear as the holes on one of them as slightly off centre. You can use a front IS to 160mm adapter to fit a 140mm rotor to the rear of an IS frame but will need some shims to space it in a bit. Most generic IS to post don't have this problem.
Posted : 30/10/2015 5:58 pm
Thanks Andy for confirmation, and useful info on the IS mount.
Posted : 30/10/2015 6:08 pm
