Brake bleeding help...
[Closed] Brake bleeding help!
1 Users
Have been recommissioning some old original hope minis that have been left unused for a decade. Stripped and cleaned added new lines and put back on bike. Front bled fine but rear was not playing ball the bleed pressure gun was just going to zero with very little liquid coming through. Tighten the bolts on the caliper and then bled using the old fashioned squeeze lever method and it worked. Are bleed guns sometimes a problem or am I likely to go back in the morning to a squidgy lever and a pool of brake fluid on the floor?
Posted : 15/02/2017 4:26 pm
