Bottom bracket drai...
[Closed] Bottom bracket drain hole
7 Users
Hi, I want to drill a drain hole in my bottom bracket, but I also want to have some sort of bung or cap for it to stop crap getting in. Any suggestions as to what I could use?
Posted : 04/11/2014 1:51 pm
Blanking Grommets
(other sizes are available)
[url= http://www.ebay.co.uk/itm/6-5mm-Blanking-Grommets-Blind-Closed-1-4-Inch-Electrical-Non-Rubber-Qty-20-/181564818649 ]http://www.ebay.co.uk/itm/6-5mm-Blanking-Grommets-Blind-Closed-1-4-Inch-Electrical-Non-Rubber-Qty-20-/181564818649[/url]
Posted : 04/11/2014 1:55 pm
Just drill the hole. Don't worry about a bung. I've always drilled, never bunged and always been okay.
Posted : 04/11/2014 2:05 pm
 jimw
When i did my Orange 5 I drilled out 4.5mm and used a 5mm tap then you can use a disk bolt
Posted : 04/11/2014 2:28 pm
Are you really going to remember to drain it every time you ride in the wet? Otherwise you're probably better off just having an open hole.
Posted : 04/11/2014 4:02 pm
Just drilled my 6 month old Cannondale Jekyll, as thats what killed the BB30 BB. Rust line along the bearings. Used a 5 mm drill bit and left open to drain.
Posted : 04/11/2014 6:14 pm
Drilled all my frames and never bothered with a bung, never been a issue with them filling with crap compared to the amount of moisture that can get retained there when there is no drain hole.
Posted : 04/11/2014 6:31 pm
Cheers guys - will just be leaving it open then!
Posted : 04/11/2014 6:59 pm
