Bottle cage with a ...
Bottle cage with a firm grip
23 Users
2 Reactions
I bought a Zefal tool bottle thing to hold a few bits under the down tube and a Zefal bottle cage thinking they would be the perfect match.  It is not a snug fit and rattles 🙁
So, is anyone able to recommend a bottle cage with an emphasis on holding the tool keg firmly with ease of removal relatively unimportant?
Posted : 24/11/2025 12:44 pm
Stainless King Cage, bendable for more grip and security.
Posted : 24/11/2025 12:47 pm
milan b. and zerocool reacted
The cage you have plus a velcro strap
Posted : 24/11/2025 1:00 pm
I have a specialized side loader.
Posted : 24/11/2025 1:03 pm
Posted by: scaredypants
That could be the solution.  I will have to check there is a suitable place to thread a strap through
Posted : 24/11/2025 1:08 pm
Another vote for the Specialized Zee, just remember to chose left or ride loading (not so important here, but just in case you ever do use it for a bottle)
Posted : 24/11/2025 1:28 pm
https://www.bikeparts.co.uk/products/elite-struka-microadjust-bottle-cage-black
I use these on my gravel bike.  Never had a bottle rattle or fall out.
Posted : 24/11/2025 1:30 pm
Specialized Zee
+1 It happy grips on to my thermo's flask (7cm), which is not quite as big a normal drinks bottle.
Posted : 24/11/2025 1:59 pm
Bontrager does a bottle cage called the Bat Cage made from recycled fishing nets that grips bottles like a determined mastiff. Just really effective in a no-nonsense, affordable way.
Posted : 24/11/2025 2:04 pm
The Elite Ciussi was always the default answer to this question.  Squeeze it to make it tighter and/or add some grip tape.
Posted : 24/11/2025 2:53 pm
Zees are great but you also need to be careful with bottles as the retention "notch" isn't always at the same height.
Posted : 24/11/2025 3:21 pm
BBB dual side loaders. Cheap and never let me down
Posted : 24/11/2025 5:11 pm
If I don't need a side loader because of weird frame shapes, my go to is the old skool Blackburn MNTN cage. Great grip, but also bendable
Posted : 24/11/2025 5:15 pm
Arundel mandible. Not cheap but I have never lost a bottle.
Posted : 24/11/2025 5:23 pm
Too many choices, I need consensus dammit! 😀
Posted : 24/11/2025 6:16 pm
Decathlon simple, plastic bottle cages hold tool bottles well. A velcro strap around the downtube, as mentioned, if you want to avoid the bolts rattling loose and losing vital tools/parts.
Posted : 24/11/2025 6:24 pm
Van Rysel 500: £4.99.
Posted : 24/11/2025 6:26 pm
After experimenting with many where people told me 'ive never lost a bottle'....and then me losing several bottles... I've gone back to lezyne flow.
Don't expect to get a bottle in or out very easily (you can, but you need the knack)
But you (really, really, really) will never drop a bottle.
I've had XL zefal magnum bottles full of water on some extremely chunky tracks and never (i.e. actually never) lost a bottle out of one.
A note of caution they may not work with all frame designs, as top loading and need the bottle to be angled a bit when going in/out
Edit. Not sure what's gone on with the broken link I posted...this is the one
Screenshot_20251124_183636_eBay.jpg Screenshot_20251124_183636_eBay.jpg Screenshot_20251124_183636_eBay.jpg
Posted : 24/11/2025 6:33 pm
Came here to recommend the Lezyne flow as well.  I have them on any bike that doesn't need a side loader
Very reasonably priced at RRP.  Tredz have them in white for a mere seven pounds fiddy
https://www.tredz.co.uk/.Lezyne-Flow-Bottle-Cage_53711.htm?variations=colour:White&sku=147280
Posted : 24/11/2025 6:54 pm
Posted by: scotroutes
I have the Zetal tool bottle and it sits slightly wonky in the Spec Zee cage as the notch isn’t aligned.
Posted : 24/11/2025 7:55 pm
Posted by: blaggers
"Standards"
Posted : 24/11/2025 8:42 pm
Posted by: blaggers
I didn't take that chance, I bought a Zefal cage to go with the Zefal tool bottle so they would be made to the same
"Standards"
but it's not merely wonky, it's loose!
Thanks for the feedback on the Zee cage 👍
Posted : 24/11/2025 9:15 pm
 mert
Posted by: lunge
It still is. I've been using them, except where sponsors say no, for decades. I still have a pair of red ones that are now a very faded pink that i bought in the 90s to match my team bike. They are still in use.
Posted : 25/11/2025 9:37 am
Posted by: lunge
Original/standard or the new Gel?
Posted : 25/11/2025 10:48 am
The Elite one Mister-P suggested is magic. Use it on a rigid MTB that used to dump bottles regularly. Never does now. Really good.
Posted : 25/11/2025 11:03 am
Portland Design Works otter cage, got one for my daughter and it's snug!
Posted : 25/11/2025 11:18 am
There is much overthinking/overspending on this thread.
Buy a cheap boggo metal one like this...
...and bend it in a bit.
Posted : 25/11/2025 11:22 am
 mert
Posted by: masterdabber
Posted by: lunge
All of the above. Even the side loader is excellent.
Posted : 25/11/2025 11:38 am
Choice made (for now), I’ve ordered the recommended Lezyne.  Looks like it will be ok under a down tube, I even splashed out the extra to have black rather than white but a tenner ain’t bad.  Just hope it can keep a grip.
I’m put off any you can bend to tighten as mounting the cage under the down tube has the potential for the weight of the tool keg to unbend it again
Posted : 25/11/2025 12:22 pm
King Ti. Ridiculous money, but mine is from 2008 and I've never lost a bottle.
Posted : 25/11/2025 8:51 pm
Specialized Zee and a strap won out in this video which also demonstrates the problem with mounting a cage on the underside of a tube
Posted : 25/11/2025 9:05 pm
