Bottle Cage - Fail ...
[Closed] Bottle Cage - Fail - Bast!
5 Users
Guys
I have on my bike two No. bottle cages. The bottle cage on the seat tube became loose. So whilst trying to tighten up the bolts I have noticed the bolts have actually sheared from the frame.
Now then, how to fix it? Ive now removed the bolts and the bit they thread into and therefore I have holes now where they used to be. Can you buy the bits the bolts crew into so I can tap em back inot the frame?
Or Zip tie my bottle cage back on, or something else?
TIA
Posted : 04/05/2010 10:55 am
A decent bike shop should be able to sort out the problem, if not your LBS then a frame refinisher. There is a special tool that allows the threaded nut part to be reintroduced into the frame.
Posted : 04/05/2010 10:58 am
You can get a cage and mount for frames without bosses. Only choice really if you don't want to repair.
Posted : 04/05/2010 11:00 am
Something like this should do it:
[url= http://www.petracycles.co.uk/bottle-cage-gizmo-clamp-32355mm-p-31535.html ]http://www.petracycles.co.uk/bottle-cage-gizmo-clamp-32355mm-p-31535.html[/url]
Posted : 04/05/2010 11:01 am
My old frame had this problem - years ago and my dad fixed it with a Nutsert. Worked perfectly.
http://www.zygology.com/productcart/pc/viewCategories.asp?idCategory=25&gclid=CJWy2M-tuKECFVKZ2AodHF3mDg
(He happened to work for Zygology at the time)
Posted : 04/05/2010 11:18 am
