As per the title, one of the bolts for the bottle cage is just turning. Any suggestions on how I can remove it with my limited bike tools or is it one for the lbs?
Posted : 11/05/2016 6:49 pm
dremel?
Posted : 11/05/2016 6:57 pm
Sounds like the rivnut has come loose. If you get the bolt out the nut may fall into the frame then rattle forever.
Posted : 11/05/2016 7:02 pm
You need to push it out. Drill a hole opposite and poke it out the other way.
Failing that, Araldite/glue gun an Allen key into it then carefully pull and unscrew.
Posted : 11/05/2016 7:05 pm
Cut bolt. Drill rivnut. Fit new one.
Posted : 11/05/2016 7:30 pm
