Bosch CX 4 motor pr...
Bosch CX 4 motor problems....
7 Users
 jeb
Hello
So my friend has this commuter bike with the Bosch cx 4 motor and intuvia display.
She got a new rear wheel fitted, and a new cassette fitted, and now it won't show
kilometers, and shifting to lower gears it only assist for some seconds, and then shuts of.
As far as I know their is no sensor on the rear wheel...? .. so it should not matter that the rear wheel has been changed, and a new casette mounted with a different gearing.
Thanks
Posted : 28/07/2022 3:46 pm
Don't all Bosch motors need a magnet either on the spoke or the disc?
Posted : 28/07/2022 3:49 pm
 K
Sounds like its missing the magnet or its not aligned on the wheel to pick up on the sensor.
Posted : 28/07/2022 3:51 pm
I'd be going back to whoever fitted the rear wheel
Posted : 28/07/2022 3:54 pm
 jeb
I fitted it .... !
but I looked closely at the old wheel... could not find a magnet!
Posted : 28/07/2022 4:52 pm
Definitely has a magnet… that’s how they work!
Posted : 28/07/2022 5:06 pm
There should definitely be a magnet. Did you swap the discs or fit a new disc?
Posted : 28/07/2022 5:07 pm
 jeb
oh man I did swap the disc..... Thanks doomanic!!!!
Posted : 28/07/2022 5:50 pm
jeb
I fitted it …. !
but I looked closely at the old wheel… could not find a magnet!
Blame "standards" and claim you "figured out a way to make it work" - you are still the hero 🙂
Posted : 28/07/2022 6:07 pm
It could have had a Shimano Steps disc on the old wheel and the magnet is not that obvious as it’s quite close to the centre. Defo needs a magnet though.
Posted : 28/07/2022 6:32 pm
 jeb
oceanskipper, I found it sitting on a round plastic dingy on the old disc, so now i will try to transfer it, so mystery sorted!
Posted : 28/07/2022 6:47 pm
There are other types of magnets available if you are using either 6 bolt or center lock.
Centerlock magnet -
https://www.bikester.co.uk/bosch-magnet-centerlock-for-speed-sensor-slim-M921997.html?&_cid=21_1_-1_9_1859_1324072__pla&campaign_detail=smart_shopping&gclid=EAIaIQobChMIoISOmZuc-QIVA-rtCh3cDQZGEAYYASABEgLgg_D_BwE
The pic is the 6 bolt one. I'm changing my wheels from the stock cheap shimano to hope pro4 and the originals are centerlock, the pro 4 are 6 bolt, so i needed a different magnet.
Thus
Posted : 28/07/2022 7:27 pm
@jeb Shimano one  looks like it clips on tbh and will probably transfer to any Shimano centre lock disc….🤷‍♂️
Or what @dyna-ti posted…
Posted : 28/07/2022 9:15 pm
 jeb
HA! .... the magnet from the old wheel sitting on a round plastic dingy, cut the magnet out and ziptied it on the new 6 hole wheel 🙂
Posted : 29/07/2022 8:30 pm
