Anyone have an OnOne Smorg (pref 27.5”) mounted on a Arch rim (S1 or Mk.3) they can give me a width measurement for please?
Bonty 2.35 is coming up too big for my frame on new wider rims so want to check the likely replacement will be narrower by an adequate margin... cheers, Chris.
Not super helpful, more of an indication...but I had a smorg on a flow (25mm internal version) and didn't think it came up very big at all.
The knobbles aren't very sticky outy compared to say a Minion so tends to look narrower despite sharing the same carcass as a 2.3 minion (maxxis make the on-one tyres).
Thanks Bill, that’s actually pretty helpful as I have a 2.3 minion on the front! Cheers.
Might give you an idea:
http://www.reifenbreiten-datenbank.de/reifen-On_One-Sm%F6rgasbord-26x2.25.html
Wow 😲 so much data - Thanks Stevied!
57.6mm it transpires (between shoulder lugs and only a tiny smidge wider on them) Very similar indeed to the dhf 2.3 as predicted by BillOddie.
58.7 on a 29 mk3 flow
