Boring question - S...
[Closed] Boring question - Stretching derailleur by 2 teeth
7 Users
Quick one -
If I have a derailleur that will take a 34t (M-390) but I want to run it on a 36t, would it work?
Stealth ad as well - Looking for 10 speed 11-36 cassette
TIA
Posted : 01/03/2022 5:45 pm
Almost undoubtedly. But the only way of knowing for sure is to try it.
Posted : 01/03/2022 5:48 pm
Cheers sounds like a goer then
Posted : 01/03/2022 6:01 pm
Should be fine, you can always fit a longer b screw if you need more adjustment.
Posted : 01/03/2022 6:17 pm
wouldn't even hesitate to try it.
Posted : 01/03/2022 6:22 pm
11-36t 10 speed Tifosi cassette at Spa Cycles for £30. Bargain.
Posted : 01/03/2022 6:24 pm
 mert
Shimano are *very* generous with their limits, i'd almost call them guidelines TBH.
I've run them 8-10 teeth past their stated wrap capacity and 4 or 5 teeth past max sprocket size. No issues, unless you do both at the same time. can get a bit grindy!
Posted : 01/03/2022 7:21 pm
Its will almost certainly work. However, my experience of this back in the 10 speed cassette extender daya ways that the parallelogram linkages wear alot quicker.
Posted : 02/03/2022 6:51 am
