Boost upgrade Q
[Closed] Boost upgrade Q
5 Users
Struggling to get my head around these new fangled standards!
I have a SRAM NX 1x11 groupset on my current, non-Boost bike.
Just bought a new frame with Boost spacing, so is there anything I can move over to the new bike? Or am I essentially gonna have to fork out for a new Boost groupset?
Posted : 04/05/2020 7:16 am
It's the hubs that will be the issue, not the groupset. If your drivetrain will take a new chainring, that's the most you will need, and you may find the current setup will work just fine.
Posted : 04/05/2020 7:27 am
No. Just a boost chainring. But you may find the current one fits anyway.
Maybe a new rear hub, if you can’t get spacers for the old one.
Posted : 04/05/2020 7:29 am
Ah, that's good news then! Hubs won't be a problem because I'm going from, 27.5 to 29er anyway, so gonna need a new wheelset regardless.
What's the best plan then? Try and fit with existing chainring and then check the chain line? Then get a Boost chainring if not?
Any links to videos showing the correct chain line? Not sure I'd be able to judge it without a good reference to check against!
Posted : 04/05/2020 9:36 am
What’s the best plan then? Try and fit with existing chainring and then check the chain line? Then get a Boost chainring if not?
Personally I'd just get a Boost ring to start with anyway as you're getting new Boost hubs.
Posted : 04/05/2020 9:50 am
I mean, SRAM steel rings (that will last a bit longer than forever) are around £15. Then you’ll know it’s right.
Posted : 04/05/2020 9:57 am
Chainline is less of an issue (IMO) than the existing chainring fouling the chainstay if tolerances are tight on your particular frame.
I've been running a non-boost 11sp crank and chainring on a boost frame for a while, with no obvious problems.
Posted : 04/05/2020 9:59 am
Brill, thanks for the advice folks.
Just checked and there appears to be 3mm offset and 6mm offset versions.
Which will I need?
Posted : 05/05/2020 3:04 pm
Depends if you're getting a Boost ring or not.
Boost - 3mm
Non Boost - 6mm
Posted : 05/05/2020 3:12 pm
Best plan is to see if it fits - if your current chainring doesn't foul the chainstay, you're good - the non-boost chainline may work better if you spend more time(do more pedalling) in the lower gears
If it does foul the chinstay or you don't like the chainline, you need a 3mm offset (boost) SRAM chainring.
Posted : 05/05/2020 3:40 pm
