Boost hub back to n...
[Closed] Boost hub back to non boost standard...possible?
5 Users
Is it possible to convert a DT Swiss boost 110mm hub back to 100mm with a change of endcaps, or are they physically wider bodies?
Google isn't getting me a definitive answer.
Thanks.
Posted : 02/09/2020 8:30 pm
No
Posted : 02/09/2020 8:38 pm
No, you can't take anything off the disc side so you'd need to remove 10mm off the drive side endcap.
Posted : 02/09/2020 9:49 pm
Superstar hubs are the same for boost or non boost, you just need different end caps and a re dish to switch. I don't know if this is the case with dt Swiss but it isn't unheard of.
Posted : 02/09/2020 9:54 pm
No, with DT the hub shells are different Boost to non Boost.
Ok, thanks everybody, unfortunately, that’s as I suspected.
Posted : 03/09/2020 5:57 am
