So, with some time likely to be weighing on my hands. I started thinking... That’s where the trouble starts
I have a set of non-Boost, Bos Devilles FCV 15mm or 20mm axle,with 160mm of travel on my Transition Patrol and a set of Ohlins RXF36’s Boost with 170mm travel on my Stanton Switchback. My Patrol has 2016 Roval Traverse non-boost wheels and the Stanton a set of Boost Hunt Enduro Wides.
I have been thinking of swapping the Ohlins to the Patrol - just because I will then have Ohlins front and rear. Then putting the Bos on the Stanton.
I understand converting the Rovals to Boost should be straightforward - based as they are on DT hubs. However, with the Hunt wheels, I think I would need a new hub or more likely a new matching wheel?
On both counts, am I correct...?
You can get Roval-specific boost kits form Specialized, so yes to that. Wheels may need a redish, but that's an easy/cheap job.
Yes on the Hunts also, no way to go boost to non-boost without a narrower hub
