Boost conversion to...
[Closed] Boost conversion to standard hubs-centrelock content
3 Users
So im toying with the idea of building up a hardtail, the idea being a whole other conversation!
Basically I have pair of wheels sat in the garage, 100mm front and 142 rear, new frame would be boost. I have seen those kits on eBay with 3mm spacer and 6 bolt rotor spacer. That's fine but could I use a centrelock to 6 bolt adaptor then a boostinator kit after that?
Posted : 17/05/2018 7:30 am
Typically the CL to 6-bolt adaptors use the CL lock ring to hold the 6-bolt rotor to the adaptor. No way of adding a spacer into that mix.
Posted : 17/05/2018 7:41 am
Look at the Now8 boost adapter for centerloc
Posted : 17/05/2018 12:18 pm
