Recently the front wheel has been getting wobbly after each ride and the bolt-through is becoming loose.
Not tight enough to start with or some other issue?
I've had the same thing with my Maxle. Was a little screw by the quick release that needed nipping up, sorted.
Ta. Will have a look at it
Hmmm... can't find a little screw on mine. I've given it a clean and tightened it up.
Check a couple of things -
Are you using the flange to get the axle tight to start? Sounds like a daft q but we've had some customers who didnt realise thats what it was for.
How 'tight' is the lever to do up once the axle is screwed in? It should have some resistance, not as much as a traditional QR, but it should need some force to close up.
As of 10 minutes ago it is "yes" to both of the above.
Don't know what it was like prior to this.
