Blowing through all...
Blowing through all rear travel, is it an issue? Increase pressure or tokens
7 Users
Bought a new to me bike recently, air shock rather than my previous coil so a bit more to set up. I am a set and forget guy not a fiddler.
Been on a couple of rides, set pressures at recommend psi, set the rebound a little slower. Front is ok but I am blowing though all rear travel. Not crazy terrain, rooty southern trails, a few drops of about 3' face height landing down a slope so a bit more total drop. Nothing big at the end of the day.
Instinct says add tokens for a ramp up but is it actually an issue? Or should I just throw a few more psi in.
Posted : 28/07/2022 8:38 am
If your happy with the amount of sag then add token/s, if it's sagged too far add some PSI.
Posted : 28/07/2022 8:40 am
The recommended pressure is really just to get you into the ballpark, you need to experiment a bit to find what works best for you. You need to find an initial pressure that gives you an appropriate amount of sag (generally 25% to 30%) so the bike pedals ok and doesn't feel mushy on smoother stuff. If it's blowing through its travel once you've got the sag sorted, you need to add tokens.
Posted : 28/07/2022 8:55 am
"blowing through travel" is one of those terms that has been used so much its meaning has become a bit blurry.
Are you bottoming it out landing these drops?
Ending up at the bottom of the travel after a series of small hits like riding over a nest of tree roots?
Finding the elastic band at the bottom at the end of your ride which you feel is unwarranted given the bike:terrain?
Posted : 28/07/2022 9:37 am
Happy with the sag.
Number three of those options. I haven't paid loads of attention during the ride to identify the exact point probably need to narrow that down.
What would your opinion be for option 1 or 2?
Posted : 28/07/2022 9:54 am
recommended psi might not equal the right sag for you kitted up. check the sag. i normally head to 20-25% in attack position. i wouldnt know the recommended PSI for my frame.
Posted : 28/07/2022 10:02 am
1 might suggest you need more pressure or tokens, 2 might suggest your rebound is too slow.
Posted : 28/07/2022 10:13 am
Agree with Mandy.
For number 3, and this is more likely to happen with a shock mounted vertically or diagonally, and in my experience seems to be a Rockshox issue - are you sure the rubber band isnt just a bit loose and is bouncing down to the bottom of its own accord while you ride, and not a result of actually getting full suspension travel?
Posted : 28/07/2022 10:51 am
Happy with the sag.
I used to run 30% rear and 20% front, was chasing progression via tokens and tunes for ages. Ended up playing with PSI and turns out 25% rear and 16% front suited me better. Don't rule out trying adding more PSI.
Posted : 28/07/2022 11:27 am
