Bloody disc brakes!
Bloody disc brakes!
14 Users
2 Reactions
Everyday road bike seems to be plagued by glazed pads/squealing on the front. Swapped out the pads and disc and after one ride it's back again. Can only presume the caliper, Shimano BR-RS785 may have a slight leak.
Do I just bite the bullet and buy a new caliper, or anyone have any tips to fix?
Posted : 26/10/2023 10:43 am
What discs? In my experience the cheaper ones that say 'organic pads only' are very prone to squealing, I've barely had a peep out of my ice-tech ones. Still do get a squeal now and then when it's wet under a hard stop, but it's just once or twice a ride not every single stop.
Posted : 26/10/2023 10:45 am
It's a road bike.. don't worry about it 🙂
Posted : 26/10/2023 10:46 am
zerocool and zerocool reacted
An Rs785 caliper must be a good few years old now, so yes, I'd go with leakiness. Both mine went a couple of years back - replaced them with deores and its been fine since.
Posted : 26/10/2023 10:49 am
@molgrips wouldn't mind if they were cheap discs but they are RT-CL800's
Those particular early road calipers are notorious for leaking. Bin then. I switched to some cheap XT versions, which have been leak-free and are less prone to squealing (I believe the pads can retract a touch more)
I'm on 105 calipers from 2021.
Posted : 26/10/2023 10:53 am
You have removed two of the three variables (pads and rotors) so, unfortunately, it is probably the calliper leaking.  When you remove the pads is there a ring of oil on the back of the pad?
@anguswells - yep confirmed - ring of oil. New caliper time
Thanks all.
Posted : 26/10/2023 10:58 am
Yeah just buy a new caliper - I’ve had a couple of Shimano road calipers do that - one of which is the same model as yours. Either replace with a new Shimano one or the Hope RX4 fits as an alternative replacement. I loved the first RX4 I had but when swapping it over to a new frame - getting another one for the other end I’ve had no end of issues with fiddly setup / bleed / leaking etc. so I’m currently less excited about them as an alternative 🤣
Posted : 26/10/2023 11:09 am
 StuE
If mine start leaking I'll be trying some of these, works on my ebike so hopefully will on the gravel bike
https://www.totalbleedsolutions.co.uk/products/magura-brake-caliper-flat-mount-black-for-mt4-mt8-sl-with-rotatable-tube-connection-2701634?variant=44125916299573
Posted : 26/10/2023 12:57 pm
I was wondering the other day if the 2 pot Magura calipers would work well on Shimano road stis…
Posted : 26/10/2023 12:58 pm
 StuE
Certainly looks to work
Posted : 26/10/2023 1:17 pm
I've a pair of 785's that leaked and I replaced with Rx4+'s that....leak.
I've repaired the 785's with eBay O rings and piston seals and they're mint again. The Rx's aren't. I even resorted to the LBS incase of of user stupidity but £180 later, they still leak. To be fair, there's £100 of new discs in there but still. Mine have been back to Hope as well. Sadly, I wouldn't bother again despite my old M4's being the best brake on the planet...
Posted : 26/10/2023 2:46 pm
Shimano BR-RS785s? I replaced one caliper, not because of leaking, but poor maintenance and A LOT of use meant the piston seized. Easily found on ebay for ~£50. They're fab brakes so I'd just replace same again if something went wrong. 8 years old now, been bled about twice maybe. They just keep going. And stopping ARF!
Posted : 26/10/2023 3:56 pm
@boblo - do you have a link for the caliper seals/o-rings?
Posted : 26/10/2023 11:57 pm
I replaced leaky GRX calipers with deore ones after they both started leaking. Been trouble free since, no compatibility issues and the calipers were cheap.
Posted : 27/10/2023 12:13 am
@belugabob
Here ya go:
Piston seals
3.0mm x 1.5mm O rings
Posted : 27/10/2023 9:53 am
My wife's SLX's used to do it - clean everything, replace pads, and low and behold start squealing and no stopping. Turned out to be where the hose is tightened into the calliper - needed nipping up tight - must have had a fine leak on braking - no such issues since. Bike was second hand !
Posted : 27/10/2023 9:57 am
@fossy That's where the rx4's leak. No amount of nipping/new hoses/new olives etc would sort. In fact, any further nipping will probably result in an advanced state of ****ed up ness. The 785's leaked at the usual transfer port o ring but I changed the piston seals as well as a precaution.
Posted : 27/10/2023 11:18 am
Cheers @boblo - ordered the o-rings, but the piston seals are out of stock, at the moment.
Not in a hurry, though.
Posted : 31/10/2023 8:21 am
@belugabob There's loads of other suppliers, just make sure you get the right sizes 👍
Posted : 31/10/2023 10:20 am
the cheaper ones that say ‘organic pads only’ are very prone to squealing
Interesting, I have the cheap shimano centre lock resin only ones (RT10 I think) and my brakes (Juin Tech R1s), which I'm pretty sure aren't leaking, shriek like a banshee at the slightest hint of moisture - gets heads turning in the thick of the school run.
New rotor time.
Posted : 31/10/2023 10:42 am
Yes, I've found some, just now, thanks.
Posted : 01/11/2023 8:37 am
