Bloody centerlock
[Closed] Bloody centerlock
15 Users
New wheels have a centerlock rotor on that I need to take off. Grab my lockring tool and it isn't deep enough to get past the 142x12 axle to reach the locking!
So now I get to buy a new lockring tool, and maybe even a centerlock to 6-bolt adapter...
Posted : 12/05/2017 4:46 pm
Adapters add play, and a hideous creaky clunk when used.
I'm a fan...
Posted : 12/05/2017 4:57 pm
I prefer centrelock but this sounds annoying!
Posted : 12/05/2017 5:20 pm
Are they hope RS4's and is the rear one?
Posted : 12/05/2017 5:58 pm
I had that problem with a DT Swiss hub. They actually do an alternative lockring which engages externally with a spanner not internally with a cassette tool for such situations but this had not been used by my bikes previous owner/ their bike shop (Grrrr).
The solution is to grind the top off your tool with an angle grinder (oo er missus) and drill the middle out a bit, then grind some flats on either side of a cassette lockring then combine the two to make a tool to remove your lockring.
You didn't have anything else to do tomorrow morning anyway, did you?
Posted : 12/05/2017 6:32 pm
Can you not just pop out the adapters, fit the rotor, then refit the axle adapters?
Posted : 12/05/2017 6:43 pm
The lockring holds the adapters in...
Posted : 12/05/2017 6:46 pm
Sounds like a stupid design.
Posted : 12/05/2017 6:47 pm
As greyspoke said, you need to use the other type of lock ring that works with a bottom bracket tool,
http://www.tredz.co.uk/.DT-Swiss-Centre-Lock-Ring-and-Washer-For-15-mm-Axles_96851.htm?sku=343590&utm_source=google&utm_medium=cpc&utm_campaign=google_shopping&gclid=CjwKEAjwutXIBRDV7-SDvdiNsUoSJACIlTqlCW-b-5N3MWheuW55CvjnrqDcaBpL7FQEjT-eObxn3xoCDRrw_wcB
like this one but probably best not to buy it from tredz, it will say in stock but it probably isn't!
John
Posted : 12/05/2017 6:49 pm
Pretty sure theres a different lock ring needed..
Shimano SM-HB20 Centerlock Rotor Lock-Ring for 15mm / 20mm Through-Axle Hubs
http://www.ebay.co.uk/itm/Shimano-SM-HB20-Centerlock-Disc-Rotor-Lock-Ring-for-15mm-20mm-Through-Axle-Hubs-/381678002750?hash=item58ddc8223e:g:MF8AAOSwc1FXaTFR
Posted : 12/05/2017 6:50 pm
Just to add I had the same issue as you with DTswiss wheels. The discs came with the smaller cassette lock rings but the DTswiss wheels came with the BB tool lock ring. I briefly used the 6 bolt adapters but they seemed pretty rubbish. Just buy centre locks.
John
Posted : 12/05/2017 6:53 pm
Given that the traditional style lockrings has already been installed, there must be a way of getting it off - removing the axle, maybe?
Posted : 12/05/2017 6:54 pm
Double annoyingly is that I want to remove the centerlock lockring so I can get the 142x12 axle out and replace it with a 135QR axle, which looks like it won't need a new lockring tool. Stuck behind the lockring is the endcap, which is now loose because the axle itself has been removed.
The current lockring is definitely a cassette lockring, and the axle is definitely a 142x12. I think I'll take the entire wheel down the LBS tomorrow and either find a tool that fits, or ask them to do it for me...
Posted : 12/05/2017 7:05 pm
If you are really stuck rossburton I can post my bodge to you. Some cassette lockring tools look to have a longer recess in the middle, so you might find one that fits.
Posted : 12/05/2017 7:33 pm
Act at your peril but I have loosened and then re-tightened a centrelock lock ring with a screwdriver and a hammer. Wasn't anywhere near as mangled as I expected.
Edit- I should add I'm not sure I'd recommend this if you have other options, just that I was frustrated, didn't have a cassette tool available and it did work
Posted : 12/05/2017 7:37 pm
That's very kind, thanks. My lockring tool requires a spanner to turn so I'm constantly dropping the tool whilst holding the spanner with one hand and the chainwhip with the other, so I've been meaning to get an all-in-one for ages anyway. Hopefully the LBS has one with a long recess as you say but it's good to have a backup plan!
Posted : 12/05/2017 7:38 pm
rossburton: Did you have any luck? I've got exactly the same issue now. Not sure what I can do now. I can't get the rotor off due to the end cap, and can't get the end cap off due to rotor.
Posted : 26/05/2017 12:44 am
I had to buy a new tool from my LBS (my 4th [yes, fourth] such lockring tool) to get the centre lock rotors off my commuter.
Posted : 26/05/2017 5:39 am
had to buy a new spanner to do same as I only had a HT2 tool with a closed back that fitted on a socket drive only good news is that it came with a different sized similar looking bit at the other end - I am hopeful this fits the new HT2 size - hate standards that don't really benefit you and need new tools
Posted : 26/05/2017 6:56 am
I like centrelock for ease but it really annoys me that they don't supply the BB style lock ring as standard.
Having to buy another £10 part after getting new rotors is a joke. I wouldn't mind if it was the £4 it should be but some places are asking nearly £15 😯
Posted : 26/05/2017 7:27 am
My CL rotors use a BB wrench! Bontrager hubs.
Posted : 26/05/2017 7:36 am
My LBS had a cassette lockring which had enough depth to fit over the cap, and is also a better tool in general so that's fine really. My old lockring tool was probably about £3 so you get what you pay for I guess.
The front wheel is 15mm so has a HT2 bottom bracket fitting, much easier! Why can't they all be like that? Anyway the wheel is not dismantled and I can't get the part I want for the hub, so it's being swapped for a hub with good old 6-bolt mount. 🙂
Posted : 26/05/2017 7:53 am
MY cassette lockring tools that didn't fit:
PArk tools cassette lcokring tool
BBB one
CRC cheapo toolkit one
The one that did fit a was (IIRC) Icetoolz. I checked this morning but it doesn't have the mfr printed on it.
Posted : 26/05/2017 7:59 am
