Bleeding old road h...
[Closed] Bleeding old road hydraulic brakes - help
4 Users
The wife has got some ultegra 2015 approx br-rs805 hydraulic brakes on her road bike that feel spongy.
When i peeled back the rubber hood on the shifter to screw in the oil fill reservoir, i couldn't see where to put an Allen key to remove the oil reservoir cap. There was a cap that needed a small screw driver to open it. When opened the thread it was too small for the oil fill reservoir to screw onto. I had a look around for another hole. Do i need an adapter? I can't one to feed oil in.
Any ideas
Thanks in advance
Posted : 15/06/2019 12:06 am
Could well be at the back of the shifter, rather than the top, often hidden from view by the edge of the bar tape.
Posted : 15/06/2019 6:57 am
`Ooooh yes. There is a diamond cover underneath the rubber hood if i pull it back far enough.
On removal there is a tiny horizontally mounted reservoir, which needs the bike to be level to fill it.
The horizontal cable routing under the bar tape is going to make bleeding interesting. I think I'll have to take the bar tape off to chase out the bubbles by making the cables not-horizontal. I'll try the lazy approach first.
It was half full until i press the brake to pump out the air. Now it's empty and no brake at all now. I'll get the tissues. Every day is a school day. Feel free to laugh. I am. LOL!
Does anyone know how to attach images from my phones gallery, or is there still only the link to URL option (IMG).
Posted : 15/06/2019 9:04 am
I use this site and I think it's the hot link?
https://postimages.org/
Posted : 15/06/2019 11:12 am
Should you not be pumping fluid in from the caliper? You'll still need a syringe or funnel on the lever but shouldn't need to remove tape to bleed the system
Posted : 15/06/2019 1:13 pm
