Bleeding brakes and...
[Closed] Bleeding brakes and this cones out
10 Users
Friend has sent me this picture of what came out of a SHIMANO brake. It's from a second hand brake. Has it been filled with the wrong fluid?
[url= https://farm3.staticflickr.com/2824/8945764388_1145167499.jp g" target="_blank">https://farm3.staticflickr.com/2824/8945764388_1145167499.jp g"/> [/img][/url]
[url= [/url] by [url= http://www.flickr.com/people/90489422@N06/ ]Alpine160[/url], on Flickr[b]
Posted : 04/06/2013 7:06 am
It's the black oil from the X-Files 😯
Posted : 04/06/2013 7:08 am
Taste it, does it taste like sh1t ?
Posted : 04/06/2013 7:09 am
Yes, it has definitely been filled with the wrong fluid - black treacle by the look of it!
You could try flushing it through with mineral oil and if you're lucky it'll be OK but I suspect it won't have done the seals much good.
Make some gingerbread?
Posted : 04/06/2013 7:25 am
dot5 that has started to destroy all the seals?
Posted : 04/06/2013 7:30 am
looking at the deore brake its probably just the original mineral oil from the factory bleed.
ive bled worse out of deore brakes that have lived a long and fruitful life.
Posted : 04/06/2013 7:36 am
his gravel boards look a bit utilitarian.
Posted : 04/06/2013 7:46 am
I flushed by M785 XTs through after a year or so's use and the old stuff coming out was discoloured but not as bad as that.
I wouldn't necessarily jump to the conclusion that it's the wrong fluid. Just change it anyway.
Thinking aloud... Could you test it by pouring some into water.
Shimano oil would separate. I [b]assume[/b] that DoT fluid would behave differently being hygroscopic. Maybe someone can confirm.
Posted : 04/06/2013 8:33 am
I have a similar picture of bleed fluid from a year old m785. It looked more like mud than oil.
Posted : 04/06/2013 9:35 am
Flush system thoroughly, and watch. If it was the wrong fluid I would have thought that as new fluid came out they would not mix... but don't know never put mineral and D4 together.
Posted : 04/06/2013 9:38 am
