Bleeding avid r sl!...
[Closed] Bleeding avid r sl!!
1 Users
As above, I cannot bleed the rear,have tried using half filled syringe at bottom and pumping up through, and tried a syringe full at the top and pumping down through, but no joy, have adjusted the bite and reach controls but still no not,the brake works,but not as good as it should be, I wonder if the piston inside the lever assembly is sticking? If I try and force the syringe it just forces the fluid out the connector,....i don't normally struggle with avids, but this has beat me!!
Posted : 21/05/2014 10:07 pm
