Anyone else had a problem?
I used it once, all fine. Then it seemed to charge ok but when I come to use it the next time, its totally dead.
Its not locked. Connecting the USB cable to the charge points and it shows green which I presume means fully charged?
But it won't switch on, whether its in the bracket or out of the bracket.
The pan adjustment screw assembly can rattle out. add loctite.
No idea what problem would be. Send it back. I'm sure they will assist.
Yeah, no problems with the adjustment once it was all tightened up, just no light action.
And I've just tried charging it just to make sure. Dead.
