isg05 mount
countersunk blackspire mounting bolts
73mm shell
1 drive side spacer
slx triple crankset with bash
chainring bolts foul the stinger mounting bolts - have i done something wrong or is this a dodgy combo?
Did you use the washers?
Manual [url= http://www.blackspire.com/site_assets/www.blackspire.com/images/dynamic/Stinger_Setup_guide.pdf ]HERE[/url]
no as this would push the stinger further into the chainring
Are you talking about the granny ring bolts?
I had a similar setup that did that.
I just fitted lower profile bolts.
yes granny ring bolts - low profile bolts - from where?
The bottom draw of my toolbox. 😆
Just file yours down a bit.
Just rode mine for a few miles til they wore down.
i would file/ride but its pissing it down 🙂
I had the same problem with my Covert. Probably about 5mm out.
I thought the ISCG mounts were off but Transition reckon they're correct - flush with the edge of the BB on a 73mm shell.
Went for a Bionicon c.guide v2 in the end. Works really well.
mines about 1mm - file time!
Just use a 1mm B/B to shift everything across a bit, saves dicking about filing stuff.
I have a Blackspire ISCG mount on my 2011 Covert with an SLX triple chainset converted to a double - no problems with mine.
finally sorted with 4 flat chainring bolts!!
I had to file mine too on my SC Butcher too
