Has anyone running a large frame with a piggyback shock successfully fitted a bottle cage?
Bird suggested to me a Topeak side- loading cage might work (it doesn’t), and that a 490ml Fidlock will definitely fit. It doesn’t look to me like there’s physically enough room for a bottle regardless of how it’s attached and I don’t want to mess about having to return a Fidlock if it won’t fit. Anyone?
Are you using the angled adaptor?
(not mine - just nabbed the pic, but you need the angled adaptor piggyback or not on Birds).
I also used a bottle relocator bracket.
Fine with the adapter on my large Aether7 so I’d imagine the 9A would be ok but…
The Fidlock fits my AM9 but you have to turn the brackets around so it sits lower, also need the angled bracket.
My Arther 7 in medium with piggyback fits a fidlock 490ml just about. So yours should be do-able
9A/ML fits a fidlok bottle easily.
Cool, thanks all - I have the angled bracket-thing, just need the Fidlock now 👍👍👍
This is the A7 with small fidlock with Bird ramp
[url= https://i.postimg.cc/g0RPsQSG/4682CBCE-8369-4A1E-8A9E-BF90E23E6885.jp g" target="_blank">https://i.postimg.cc/g0RPsQSG/4682CBCE-8369-4A1E-8A9E-BF90E23E6885.jp g"/> [/img][/url]
The Bird front triangles aren't that spacious. I guess they'd get more space with a shorter top & down tubes bit at the front, and elongating that bottom bit while angling it further down.
