Sold out, as with most bike related things.. Decent alternative please thank you kindly 🙂
I wouldn't use there tape anyway. It's destroyed my frame. All the glue has bonded with the paint, took ages to peel just the top tube piece off and then hours to remove the glue which has left my paint dull. Left the rest of the tape on the bike even though it's lifting in places.
cheers, i've never had a problem with it mind. What would you use instead?
well quite
@robj20 - did you heat it up first? Comes off a lot more easily and then a wipe down with IPA to remove the residue.
Shack Wrap do blank sheets and generic kits (which work well with simple, tubed frames).
