The 200 seems to have a different attachment to the others - the adapter won't fit even though the box claims it's compatible with the helmet and OIF mount.
Anyone else had this issue? Have they changed the mount, since this was bought a few months after the my other two.
Mine is also like this and I have had it since September. The post sticks out further than the mount. I gave up in the end though you could bodge something I’m sure.
A plastic washer would do the trick, just wondering if there's something I missed.
Update (cos I know you're all thrilled): I noticed that the threaded insert had pulled out of the plastic boss by about a mm. Problem solved, I thought, so I glued it back in and knocked it home and it's still loose. Now I just need a thinner washer than I thought. FFS.
