anyone know any please.... 😀
Foes?
Orange st4?
what about axle path?
very interesting article in dirt this mont
merida/bergwerk/centurion/carrera LRS (short travel versions, things like the transmission LRS are closer to 2.8:1 i think).
The old Spec Epic too I guess, although not too sure about that though.
Are there going to be many with air shocks ? Isn't the longest fox stroke 57mm ? So for 2:1 that would be 4 1/2 inch travel, but bikes with around that travel run 50mm stroke or more likely less ?
And anything with a coil is probably going to have more travel, I doubt a 6 " travel bike is going to run a 3" stroke coil shock.
So that leave Foes then & maybe the ST4 as mentioned above.
Old Nicolai Helius FR ran nearly 2:1 on the shortest travel setting too.
[url= http://www.nicolai-uk.com/index.php/2007/05/helius-fr-07-what-mtb-review/ ]Helius fr[/url]
santacruz blur 4x is pretty much 2:1, 115mm from 50mm stroke shock. prob too short in the top tube for you though.
the new superlight is 100mm travel from 50mm shock so 2:1. my dad rides one with a 120mm fox float up front and loves it, i borrowed it but put some heavy wheels on and it was pretty good, took some getting used to a steeper bike and a bit flexier than my 5 but no more than most full sussers. a very fast, fun singletrack bike but didnt suit my 'crash through everything' take on riding. sorry dad.
Cotic Hemlock with the short travel rockers is a 2:1 ratio too. 200x57 Fox RP23 shock.
All Foes frame use a 2:1 leverage ratio. The benefits of 2:1 are similar on something like an orange ST4 & although it has a custom tuned shock, 2:1 frames dont work correctly unless its coupled with a high volume shock like the Curnutt which allows you to run much lower pressures.
The shortest travel Foes with an Air shock is the Prolite 2:1 which has 3.5" travel & all frames from the XCT-5 (5") upwards have a Coil or Air shock option.
J
Corsair Marque? 5" travel, unique linkage, pedals amazingly well and corners like you wouldn't believe.
http://www.corsairbikes.com/fly.aspx?layout=bike&taxid=61&sublayout=biketech
I nearly bought a Marque but the 9lbs + weight put me off in the end.
