Bike technology tha...
[Closed] Bike technology that should have worked?
51 Users
What was it for you, URT, inverted forks, suspension seatpost, etc, etc, for me it has to be flippy shifters, a good tech that came with the added bonus of surprise, whatever happened to this stuff, why didn't it take off like it should have?!
Posted : 11/10/2020 11:18 pm
Gearboxes
Posted : 11/10/2020 11:36 pm
I had some inverted forks back in the 90's. "Hanson" I think they were called?
Went straight back to the shop as their for/aft play was shocking straight out of the box. Got some Manitou 2's instead. Loved those.
Posted : 11/10/2020 11:39 pm
It did take off, but then it landed again- uturn forks. Brilliant idea, a properly adjustable travel fork that wasn't just a crappy climbing mode. I had a set in my Soul, and it really was like having 2 versions of hte same bike, a short travel xc dagger and a 130mm trailbike hammer. But apparently turning a little dial was too hard so TALAS won that particular war, despite being shite.
To be fair, improvements in bike design took away a lot of the desire for "climb mode" but my Solaris could totally benefit from a good old u-turn coil fork.
Posted : 12/10/2020 12:03 am
U-Turn forks worked well (I'm still running some), but were expensive and I think the geometry changes recently probably made it less useful.
Flippy-shift was a way of bundling Shimano brakes with drivetrains. People wanted to mix and match components.
Low-normal derailleurs probably had benefits but experienced riders were used to the existing direction and had no interest in changing. Maybe if they'd managed to make a shifter that worked in the opposite direction so that riders didn't have to reprogram themselves - but that might have been difficult because you'd have to have a lot more leverage for the finger lever than before.
Posted : 12/10/2020 2:29 am
URT has worked in certain circumstances, Mr Big ST10's were pretty well rated.
Also rocking some U-Turn Rev 426's, brilliant forks.
My submission though is Truvativ's Hammerschmidt cranks. Just saw someone fit a set to a singlespeed slopestyle bike and they make so much sense. Oh, and Rollamajigs! Fitted one to my SLX mech so I could cleanly route the cable along the chainstay on my Pitch. No idea why they got killed off.
Rapid rise should never have happened though, I've only just replaced the XT mech that has been making my life a misery for the past decade (yes, I know!).
Posted : 12/10/2020 5:08 am
^^I think SRAM killed off Rollamajigs as they basically incorporated it into their mechs.
Rapid rise deserved it's demise, just like biopace. Oval rings are another story though.👍
Posted : 12/10/2020 5:20 am
SAFE (Scott Allen Fife Engineering I think it was) made a hydraulic line that ran between conventional shifters and mechs. Apparently, the resulting action was noticeably lighter. This was so ahead of its time that it predates most disc brakes and full suspension frames.
It would have been great to see that take hold.
Posted : 12/10/2020 6:47 am
 igm
Rollamajigs still come up as NOS.
I keep a couple in the spares box as they offer a good solution to bad cable routing.
Posted : 12/10/2020 6:58 am
Standards that remained standard without 101 minor variations to ensure riders couldn't mix-and-match components.
Posted : 12/10/2020 7:00 am
20x110 front axles. Worked really well and got replaced by something worse. We are almost back there now after lots of pointless tweaking
Posted : 12/10/2020 7:03 am
Drum brakes. Set and forget but far too heavy, and need to be slightly larger diameter.
Belt drive - overpriced so killed off by not making it past the early adopters.
As for gearboxes, I think there's still hope, especially if commuting on a bicycle gains in popularity.
Going back a few decades, Sunbeam had a fully enclosed oilbath with a hub gear, but the wheel was quickly detachable with no need to touch the chain - the cog and chain stayed in position. That would have benefitted from development. It would work well now with a carbpnfibre chaincase cum chainstay, with the derailleur and cassette contained within. Imagine a derailleur and crankset and chain that would last the life of the bike.
Which brings me to single sided wheels, ie single leg 'fork' and chainstay. Saves weight, simplifies puncture repairs (ie faster).
Posted : 12/10/2020 7:47 am
 5lab
I'd love to see a decent gearbox (that shimano patent looked promising) but I think ebikes will kill them off for commuters. Even a moderate ebike motor will keep most of the population plodding along at 15mph up most road hills, at which point, why do you need anything other than singlespeed?
there's quite a few DH-originated standards that should have won through - 1.5" head tubes (stronger, lighter and stiffer than tapered), 150mm x 12mm back ends, etc.
32" wheels. a couple of niche makers have played with them, but if you can get 29" under a DH rider, we should have 32 (or bigger) under xc by now
Posted : 12/10/2020 8:17 am
Looks like a rollamajig replacement is available still from that Aladins cave of bike bits you need but no one else has (SJS cycles).
Posted : 12/10/2020 8:53 am
5lab
there’s quite a few DH-originated standards that should have won through – 1.5″ head tubes (stronger, lighter and stiffer than tapered), 150mm x 12mm back ends, etc.
I'm nt sure 1.5" steerers are lighter, given the need for a much larger had tube on the frame, a bigger stem, etc Tapered is strong where it needs to be - at the join to the crown.
Posted : 12/10/2020 9:01 am
I hope to see gearboxes but I fear it will be hard to get the weight and cost down low enough. These things are always a balance between cost, weight, performance and other factors so not always a straight fight between the best engineered solution...just look at telescopic forks vs. linkage forks. as far as engineering is concerned linkage forks should win hands down, but successive attempts at them succeeding in the market place have failed...bearing in mind they have a way to go regarding development to get designs as mature as telescopic forks - which is difficult in an open market.
Posted : 12/10/2020 9:05 am
upside down forks seem to be the majority in the motorcycle world, why did they never truly take off? Look cooler if nothing else. XC had the RS1 recently, and there is an obscure (ie not from RS or Fox) downhill fork. Plus the lefty of course.
flippy shifters
god no. I cant even get the shifters where I want with matchmakers, have to use separate clamps for shirfter and dropper so my thumbs can press the buttons without contortion. Whatever photograph of western males shimano uses for its ergonomics is not representative of my body shape.
Gearboxes, still possible just expensive to develop and get enough sales to drop the price.
Customisable geometry. Base frame with different bolt on dropouts to change geo. Or if full suspension rear triangles and linkages. Buy a frame and build the bike you want. Fancy a change? Tweak a few bits for a different feel. Kind of like this flip chip stuff but more.
32" wheels sound horrible for anything other than mile munching bikes. The BB drop would be huge for a start.
Posted : 12/10/2020 9:06 am
Flex.
Posted : 12/10/2020 9:11 am
Rapid Rise rear mech. Teh shizzle.
Posted : 12/10/2020 9:20 am
Gearboxes, linkage forks, belt drive, electronic shifting, basically anything that is costly to make even though it's probably slightly better than the 'standard' part - if the advantage over the normal stuff is minimal for most people, it's gonna have a hard time hitting the mainstream.
Ebikes could have gone this way, the difference being that the advantage they offer is huge over a normal bike so the increased cost/weight/complexity is less of an issue.
I'm more than happy for stuff like this to be a bit niche, so long as the manufacturers can make enough to keep going and keep developing new parts.
Posted : 12/10/2020 9:24 am
 Sui
specialized did this ages ago on the FSR's, and people sill adding nagle sets etc. Problem is, if you give too much to the end user to play with, they'll break it and then they'll be going all US and suing everyone..
Posted : 12/10/2020 9:28 am
Yep.
URT did it's job too as in being a soft landing for those who were scared of these new fangled full suss bikes. Served it's purpose then died off.
Posted : 12/10/2020 9:29 am
As for gearboxes, I think there’s still hope
They will always be more expensive, heavier, and draggier than a derailleur system. They have a solid niche thing going, but it's hard to see them ever being more than that.
Posted : 12/10/2020 9:31 am
 igm
sparksmcguff
I thought you meant my garage.
Posted : 12/10/2020 9:32 am
Low-normal derailleurs probably had benefits but experienced riders were used to the existing direction and had no interest in changing. Maybe if they’d managed to make a shifter that worked in the opposite direction so that riders didn’t have to reprogram themselves – but that might have been difficult because you’d have to have a lot more leverage for the finger lever than before.
The changing was in the mech, it was that which was Rapid Rise. Shimano's mistake was trying to introduce both. If they'd have done RR rear mech with trigger shifters OR Dual Control shifters, it might have worked.
Dual Control is (IMHO) brilliant, still got a set on my MTB. However it's running with a regular rear mech which makes far more sense in terms of the way the shift levers operate. You use the extra force of the hand pushing down to go to bigger cogs and just a quick tap up in combination with the spring of the mech to go to smaller cogs.
Posted : 12/10/2020 9:39 am
TheBrick
Nicolai/Geometron have managed that, you can adjust chainstay length, seatstay length and travel on the G1 with bolt-on parts. Covers a range of geometry and wheel sizes.
Posted : 12/10/2020 9:41 am
They will always be more expensive, heavier, and draggier than a derailleur system. They have a solid niche thing going, but it’s hard to see them ever being more than that.
*insert suspension comment about being heavier, draggier and (massively) more expensive*
I want a Pinion HT next.
I've got a soft spot for rapid rise because I came up with the idea about a year before it was released. I was dead chuffed I'd thought of it, and never had a problem with it. Not sure why it wasn't liked, but I don't take it personally!
Posted : 12/10/2020 10:13 am
 DrP
I've been looking at Guerilla Gravity bikes/frames..
They seem to offer this.
One front triangle, and multiple seat/chainstays and what nots to bolt to it..
DrP
Posted : 12/10/2020 10:19 am
e-bikes will always be much more expensive than non-e though.
I reckon upside-down forks are top of the list of things we should be riding but aren't. Especially now that discs are ubiquitous. However I can imagine a leaky seal would end up being pretty disastrous...
Posted : 12/10/2020 10:54 am
It did take off, but then it landed again- uturn forks. Brilliant idea, a properly adjustable travel fork that wasn’t just a crappy climbing mode.
Yeah, and well engineered too. I have a vivid memory of seeing some U-Turn forks for the first time in a bike shop in Manchester. The guy there was telling me they were decent and I simply didn't believe the adjuster work well. He made me turn the dial and I was instantly impressed - silky smooth. Little did I know they even stayed silky after years of slop.
I also really liked the Marzocchi lock down forks - I can't remember what the tech was actually called or what forks they were on but you basically turned a lever and the fork dived down for ~80mm of active travel - perfect for steep climbs.
EDIT: It was called Marzocchi ETA.
Posted : 12/10/2020 11:04 am
However I can imagine a leaky seal would end up being pretty disastrous…
Oh God, not another Shimano brake thread, please.
Posted : 12/10/2020 11:06 am
I was going to say ATA ,was one or the other. Flip the lever, then chuck all your weight over the front and it stayed down
Posted : 12/10/2020 11:08 am
“Customisable geometry. Base frame with different bolt on dropouts to change geo. Or if full suspension rear triangles and linkages. Buy a frame and build the bike you want. Fancy a change? Tweak a few bits for a different feel. Kind of like this flip chip stuff but more.”
Specialized have done this on the new Stumpy Evo - head tube inserts to give three different head angles, flip chip at the chainstays to give two different BB drops (which also changes all the angles) and chainstay lengths, and a different linkage to go 29/27. So six stock geometries, and twelve if you buy that linkage.
And the latest Geometron is almost infinitely adjustable with the Mutators.
Posted : 12/10/2020 11:12 am
I also really liked the Marzocchi lock down forks – I can’t remember what the tech was actually called or what forks they were on but you basically turned a lever and the fork dived down for ~80mm of active travel – perfect for steep climbs.
Pace did this too in ooh, 2004?
ATA on Marzocchi forks is infinitely adjustable with a winder, like U-Turn. At least, it is on mine. I don't adjust it during a ride but it makes it easy to fine time your travel to suit your bike and riding. I run mine about 5 half-turns from max.
Posted : 12/10/2020 11:14 am
All of that can be addressed through engineering design and development...but that is costly and the end product will be costly...at least initially until volumes go up and prices come down..that is the biggest barrier to entry for alot of these new technologies...can you get enough early adopters to pay the premium for an unproven and under-developed technology, that wont be as good as the established products initially, to get you sufficiently up that technology maturity curve before you go bust. Plenty of bike industry suspension experts have tried and failed. That tells you two things...the real experts who know more about this stuff than we do, see great potential in these new technologies and designs and that they are willing to put heir reputations on the line, risking their own money and pursue them. And secondly it is very hard to make a go of bringing a successful product to market (high barriers to entry).
The challenge is that the balance of attributes of the existing systems are good - they're well known, people feel comfortable they understand the current technologies, they're cheap enough, they are happy to accommodate their significant shortfalls (mostly unaware of them as they know no difference) and the performance to price/cost ratio is very good. Arguably that makes them the best suited technology for the application. But if you're approaching it from a pure performance and engineering perspective then the current designs are 'sub optimal' by a significant margin.
But fork companies are getting greedy. How they're justifying £1000 for a set of forks in beyond me. totally unjustifiable for a product that hasn't really been improved in the last 10 years. They've fettled the designs but they're basically the same there were 10 years ago. Just marketing giving the perception of better value and pushing up the premiums.
Posted : 12/10/2020 11:17 am
Lightweight long travel/travel adjustable triple crown forks.
Posted : 12/10/2020 11:19 am
ayjaydoubleyou
USD only took off for motorbikes due to fashion. When they really caught on- 1996 to 2000 essentially- they were almost always the worse option. For the same spec level, flexier and heavier. And often functionally the same inside.
But they do look cool, so people would tolerate a bit of downgrade. And weight differences do mean less in a 200kg bike. But maybe more significantly, claimed weights at the time were all absolute fiction
So basically, the reason they caught on with motorbikes is that it's easier for a customer to weigh a pushbike.
Posted : 12/10/2020 11:31 am
 5lab
I’m nt sure 1.5″ steerers are lighter, given the need for a much larger had tube on the frame, a bigger stem, etc Tapered is strong where it needs to be – at the join to the crown.
there was some testing at the time when tapered was being released that showed it was (marginally) lighter for the 1.5 - the forks were a bit lighter, and the frame was negligably heavier (the normal wider tubes/thinner tube material thing, I seem to remember)
32″ wheels sound horrible for anything other than mile munching bikes. The BB drop would be huge for a start.
why's that? 29ers (similar gap to a 26" wheel) are percieved by many to be better overall these days - 32ers are coming (trek are playing with them I think), its just a matter of time. They would definitely have some disadvantages, especially on smaller frames, I'm curious why large BB drop is one of them though?
agreed that a single speed e-bike will always cost more than a single-speed non-e bike, but I'm not sure it'll always be more than a gearbox bike. A bottom end hub gear is £100, an 11 speed alfine (which is about as mainstream as you can get) is £400. I recon it won't be long till the gubbins for an ebike are less than (or close enough to not matter) £400
sneaky edit : ah - it seems that £400 was the first price I found, the alfine can be a chunk cheaper than that. Still, point stands, maybe?
Posted : 12/10/2020 11:32 am
Yup, I owned an RC-40 for a while. The travel adjust was a PITA, sometimes you'd be riding along a perfectly flat surface and would hit a small pebble, there would be a "zzzp!" noise from the right leg and 30mm of travel would magically disappear. Rockshox's U-Turn was far, far better.
There was a compression blow off valve on the right leg that allowed you to slap a dial on the right leg and lock the fork in a reduced travel mode until the fork encountered a bump and you'd ping back to full travel again. TBH this was a nice touch, although the first time that I tried it the threshold dial was fired across the bike shop floor because the dial's grubscrew hadn't been tightened properly during manufacture.
Posted : 12/10/2020 11:35 am
1.5 Headtubes look miles better on longer travel bikes which typically have wider tubing, IMHO, where the weight penalty is meaningless (in reality, if not in marketing). Weeny little 1 1/8 steerer stem clamp is always a disappointing feature on enduro bikes that have them.
Another vote for shimano dual control being excellent, loved the set I had on an old scalpel. Obv problems with locking you in to that system though.
 Sui
So basically, the reason they caught on with motorbikes is that it’s easier for a customer to weigh a pushbike.
that
but also, i don't about you lot, but the lowers on my forks are battered after 6 years, upsidedown forks,would die (i know you can have the guards, but they're not perfect)..
All of that can be addressed through engineering design and development…but that is costly and the end product will be costly…at least initially until volumes go up and prices come down
No, those are fundamental limitations. A gearbox needs a lot of precisely machined parts whereas a derailleur can be made from stamped parts. The precision machining will always be more expensive. Mass-production won't reduce the cost to that of a derailleur because the machining equipment required to produce the gear sets is expensive. If you want to increase production by 100-fold, you need 100 times the investment in factory equipment and skilled operators. Shimano already mass produces gear hubs so there's unlikely to be huge areas to cut costs any further than that.
A gearbox has sliding friction where the gear teeth mesh. Car companies and everyone else who makes power transmission systems have been working for decades to minimize those frictional losses, but they will always be more than a properly lubricated derailleur system. There is no magic solution to that, it's fundamental to how gearboxes work.
Posted : 12/10/2020 11:45 am
 hugo
Cables for gears are a weak area that should be hydraulic really, however, fly by wire leccy ones will be the future anyway.
Non sealed wire cables with mud and grit. Not ideal.
Posted : 12/10/2020 12:13 pm
 5lab
There is no magic solution to that, it’s fundamental to how gearboxes work.
depends on how the gearbox works. If you're using a gearbox like a car one (I don't know the technical term) then you're right - if its just a mech and chain in a box (as the honda system, and the shimano patent) then you can still have the cost/friction benefits of a mech system, but without things dangling off the back of the bike
Posted : 12/10/2020 12:15 pm
for me, Rapid Rise mechs worked really well with gripshift. you could shift into easier gears whilst rotating your hand to grab the brakes, it was a subtle move, but worked well compared to the push thumb whilst extending forefinger operation of normal trigger shofter and normal mechs.
I think I could use a 10 or 11 speed gripshift (x-actuation) old 9 speed mech and a j-tek shiftmate to get that to work on my 10 speed setup..
I loved that combo as well lovewookie… rapid rise + Sachs wavy shifter.
Posted : 12/10/2020 12:17 pm
Yup, I owned an RC-40 for a while. The travel adjust was a PITA, sometimes you’d be riding along a perfectly flat surface and would hit a small pebble, there would be a “zzzp!” noise from the right leg and 30mm of travel would magically disappear.
I had some RC40's too and loved them. From memory it was the other way round, you turned the lever to lock it down but if you hit something they'd go back to full travel? Could be getting them mixed up with the Pace based DT Swiss I had later though? Thinking about it, mine were 2006ish so they'd maybe fixed it by then? Either way, they were ace.
Posted : 12/10/2020 12:19 pm
I'm not talking about travel adjust, I mean the lock-down feature that you describe in your second paragraph. It was useless for locking out on the road, as I hated riding with the bars 30mm lower, but it was quite nice on silly steep climbs.
Posted : 12/10/2020 12:30 pm
Upside down forks.
We've just had some well used SIDs and an RS1 serviced. Forks mainly die due to dirt and water ingress. The RS1s were like new inside as water just can't get in unless you store them upside down, and the bushes are permanently bathed in lube oil. The SIDs scraped through service but are on their last legs. We've been paranoid about not bashing the stanchions on the RS1 (would prefer if they had a bashguard kit) but otherwise they've been ridden in the same conditions.
Posted : 12/10/2020 12:33 pm
Good point about the friction benefits, but that depends on whether it can be made reliable enough - a snapped chain in a gearbox is a whole different thing than in a traditional derailleur system.
A derailleur-in-a-box will always be more expensive than a traditional system because there are more parts to manufacture. You need a casing that has to be mounted in the frame and sealed against dirt and water. The frame will have to be designed around the packaging limitations of the transmission, which may add expense, especially for suspension bikes. There will be packaging limitations because you need a certain amount of chain slack to be able to shift gears, so there will be a limit to how close the two cassettes could be, plus you need to fit in a chain tensioner.
Plus the derailleur and shifting mechanism will probably need to be more precisely manufactured. Instead of one cassette, you need two, otherwise you'd need an insane amount of chain slack. You need at least two shafts and two sets of bearings, and you may need two derailleurs or some sort of complex derailleur that alternately moves the tensioned and slack sections of chain (i.e. you're basically alternating between shifting front and rear gears on a traditional derailleur system). It might be cheaper than a traditional gear set, but that's assuming that it can be made reliable enough for mass-production.
Posted : 12/10/2020 12:48 pm
The grease ports WTB used to have on some of their hubs. In fact, it'd be amazing if all bearings on a mtb had grease ports or similar.
Posted : 12/10/2020 12:55 pm
There was a compression blow off valve on the right leg that allowed you to slap a dial on the right leg and lock the fork in a reduced travel mode until the fork encountered a bump and you’d ping back to full travel again.
I don't think anyone has mentioned Terralogic. It sounded like a great idea, apparently the reality was that you hit a bump, lost your fillings, and only then did the fork release?
Posted : 12/10/2020 1:03 pm
Wasn't that adjustable? It's what Specialized have on their XC bikes isn't it?
Posted : 12/10/2020 1:08 pm
Electronically controlled suspension damping should be a mainstream thing by now.
K2 / Proflex were messing with this in the late 90s. Yes it was a bit rubbish but everything was a bit rubbish back then.
Posted : 12/10/2020 1:18 pm
mick_r
....water just can’t get in unless you store them upside down, and the bushes are permanently bathed in lube oil.
Yeah, they just make sense. Weird that nobody has made it work for mass market, you hear the stiffness argument but the Lefty seems to manage with half a fork
Posted : 12/10/2020 1:26 pm
Geomatron, remember them? Adjustable on the fly geo.... Not sure what happened to them. Never owned one.
Posted : 12/10/2020 1:31 pm
The main difference and why motorbikes have upside down forks is that you have the biggest tubes at the head tube area, with triple clamps so maximising stiffness. Plus you can have a massive bolt through axle without worrying about ease of removal etc.
And weight isn't as much of an issue on a motorbike that weighs 180kg.
I don't think gearboxes will ever hit mass market, they're too expensive to make and require a proprietary mount so the bike has to be designed specifically for them. On the shifting under load subject, it's not that you can't shift under load, it's that your hand can't generate the require force to shift under load - a future electronic system with a strong servo/motor might get around this.
Posted : 12/10/2020 1:32 pm
I’m not talking about travel adjust, I mean the lock-down feature that you describe in your second paragraph. It was useless for locking out on the road, as I hated riding with the bars 30mm lower, but it was quite nice on silly steep climbs.
That's how it's meant to work, but the right leg travel adjust on my RC-40s regularly failed and I ended up having to return them to Pace several times. Mine never quite worked properly.
I had some RC40’s too and loved them. From memory it was the other way round, you turned the lever to lock it down but if you hit something they’d go back to full travel? Could be getting them mixed up with the Pace based DT Swiss I had later though?
No, you're absolutely right - I was referring to the build quality of my own RC-40 forks which was patchy at best. When they worked, they were lovely forks but all too often they didn't.
Posted : 12/10/2020 1:35 pm
Geomatron, remember them? Adjustable on the fly geo…. Not sure what happened to them. Never owned one.
Bionicon, wasn't it?
Posted : 12/10/2020 1:48 pm
why’s that? 29ers (similar gap to a 26″ wheel) are percieved by many to be better overall these days – 32ers are coming (trek are playing with them I think), its just a matter of time. They would definitely have some disadvantages, especially on smaller frames, I’m curious why large BB drop is one of them though?
You can't just keep adding. More must be better, not always.
Greater BB drop = harder to lift front end. Add the additional wheel size and the bike is going to be much harder to manipulate (more leverage harder to move weight over pivot). MTBs are already quite hard to get the front up as seen by everyone having to push down to pull back and up. 32" wheels would be very hard work for all but the tallest.
Posted : 12/10/2020 1:49 pm
ta11pau1
All motorbikes have triple clamps regardless of fork design though, and the bolt through axles work the same way whether up or down, and are pretty comparable. Big tubes are good for fore/aft stiffness but losing the fork brace is bad for twist
Posted : 12/10/2020 1:52 pm
That’s how it’s meant to work, but the right leg travel adjust on my RC-40s regularly failed and I ended up having to return them to Pace several times. Mine never quite worked properly.
Ah, so you were riding along with them locked down?
Weirdo!
Ah, Leftys. I think the most interesting think about them is that they use square slider tubes needle roller bearings, and rely on a boot for a top seal, in the name of friction reduction. And it works too. I think the single-sided bit came about because this solution is heavy, but has the side-effect that it can't twist like cylindrical bushings can. So you can get away with one leg to eliminate the weight penalty.
Posted : 12/10/2020 2:13 pm
Wondered when a lefty fork would come up and as an owner of one I was going to suggest it myself. The thread title could pretty much apply to Cannondale anyway. The lefty though, great when working properly, massive pain when it isn't and usually hugely expensive to rectify.
Posted : 12/10/2020 2:45 pm
Leftys do work pretty well, and no doubt if they were mainstream with the same sort of budget as other forks would be better still. They just look weird, is all.
Unless on a fatbike, where they look awesome.
Posted : 12/10/2020 2:54 pm
Wasn’t that adjustable? It’s what Specialized have on their XC bikes isn’t it?
TerraLogic was just a basic lockout with a blow-off / bypass valve.
Before suspension design and tech had learnt how to overcome wallowing and sagging, you had to put a lockout on it to be more efficient but then riders would forget to unlock it and set off on a descent with the fork or shock still locked out which usually broke it.
TerraLogic wasn't necessarily an improvement in suspension tech, it was a way of trying to make the thing more idiot-proof!
Specialized refined the concept with the Brain rear shock which (after a couple of iterations) was very good indeed.
Posted : 12/10/2020 3:02 pm
1.5in was better, looked FAT and was also much cheaper in terms of machining especially on aluminium frames. This and the prohibitive cost of retooling for smaller frame manufacturers has lead directly to the straight 40mm headtube with silly external bearing on the bottom bodge.
Posted : 12/10/2020 3:04 pm
@honeybadgerx    I have a WTB Momentum headset on my folder (itself a long bankrupt Mezzo) with grease ports on both races. Works a treat even after 15 years.
Posted : 12/10/2020 3:11 pm
That's an experience everyone should have at least once.
Posted : 12/10/2020 3:21 pm
good ol' Cannondale with the ideas 🙂
Is my memory faulty, or didn't they do a rear suspended road bike way back when?
Posted : 12/10/2020 3:29 pm
Do you mean Bionicon bikes?
Posted : 12/10/2020 4:03 pm
By the time I was on suspension bikes, decent forks and shocks had blowoffs anyway. (my Revs made a funny noise if you rode them too hard while locked out).
This is another "bike technology that did work, and does work, and has gone away a bit, but should and probably will come back" though- propedal. I hate this current idea that you just throw antisquat at everything and suddenly all bikes can climb and descend perfectly on a single shock setting. Never ridden a bike yet where it's remotely true (the closest I've found is Trek, but that's because they basically have 2 shock settings in one- the antisquat and the clever shock work in hand. But it still benefits from propedal).
I'm not saying that it's not a valid way to build a bike- I had a BMC Trailfox 29, which was genuinely brilliant- fantastic shape, best geometry I'd ridden at the time, it's one of those bikes that you can look at new bikes today and see much the same numbers. But I hated, absolutely hated the suspension. Bottom line was, it didn't know whether the lump you're pedalling at was a rocky climb, or a fort william downhill rock garden, and it reacted the same to both.
The race team loved it- and to bbe fair, most times for me, it was fast. Just, fast and horrible feeling.
Meanwhile, the propedal also can't tell if you're on a climb or a rocky downhill, but it has a lever. There's other tricks like brain shocks, sensor controlled shocks etc but all their development has done is made them react faster and faster- which no matter how fast you get, can never beat foresight.
Today's awesome bikes with today's awesome materials and designers AND a propedal switch, that's an awesome combo.
Posted : 12/10/2020 4:04 pm
1.5 steerers, (imagine the One Up EDC on that).
Upside down forks, we’ve been sold on the ‘stiffness = better’ marketing but whenever I’ve ridden Dorados they’ve been as good as any thing else out (and much older) and my only SC Shivers might have been been a bit flexy but they rode as well as anything else in the market.
Gearbox will get there one day.
20mm front axles
Grease ports
Sensible standards that last more than 10 minutes.
Posted : 12/10/2020 4:08 pm
Ha! Good one. 😀
Posted : 12/10/2020 4:18 pm
Is my memory faulty, or didn’t they do a rear suspended road bike way back when?
I can remember there was a Bad Boy version of the Jekyll in the early 2000s
Posted : 12/10/2020 5:19 pm
Rohloff have been developing their gearboxes for what? 20 years now?  And Shimano have been doing gearboxes for years and years as well, and don't rate theirs for off-road at all. If they thought that 1. there was a market for them, and 2. they could make them cheap and reliable, they would've done so already, no?
I like the Honda cassette and derailleur in a box though, that is a good idea. Comes with many many issues of it's own though.
Posted : 12/10/2020 5:58 pm
I don’t think gearboxes will ever hit mass market,
Hub gears are the norm most of europe on anything but entry level bikes - but then that market is utility led not fashion
Posted : 12/10/2020 8:39 pm
Oh shut up.
Posted : 12/10/2020 8:46 pm
Hub gears are the norm most of europe on anything but entry level bikes – but then that market is utility led not fashion
Difference being that you can buy a shimano hub gear for £100, that requires only sliding dropouts, nothing more. That same bike will also fit regular derailleur gears.
A pinion gearbox is close to £1000, and a frame that will fit one cannot fit regular gears with a normal bottom bracket chainset.
For the MTB market that's not an issue, but getting costs down to a few hundred quid will be extremely difficult. I have no issue with this.
I did a cost comparison using a Ti frame and an XT groupset vs a Pinion gearbox with belt drive, the pinion works out at around £900 more. If you're building a several thousand pound bike, it's not so hard to accept that cost.
As someone else said, if there was a market for mass produced gearbox drivetrains, you can bet either Shimano or SRAM would have developed one by now. I for one like that MTB has the 'cutting edge' area of development.
Posted : 12/10/2020 9:14 pm
