I can't fit my new FS on my bike stand due to the suspension and reverb. What are the stands called that go through the BB? Any recommendations? cheers
Andy Stand?
I have one of these, it sits underneath the bottom bracket. Weight sits on the front wheel so you can adjust gears etc but if you take the front wheel off - it will then rest on the rear wheel:
http://www.od-designs.co.uk/
You can clamp a Reverb, just not the moving shaft and you can't go crazy when you tighten it up.
Cheers, Andy stand is the one. My reverb doesn't have enough none moving shaft available to use.
Can't you clamp on the front of the seat for example ?
I just have a cheap and nasty old seat post that I bung in when I want to put the bike in the stand. Saves any possible damage to a nice one.
