Bike cleaning produ...
[Closed] Bike cleaning products
40 Users
I've never really bothered with any of these bike cleaning sprays. Does anyone here actually use them? Just wondered if they are actually better than a bit of warm soapy water and elbow grease. I was looking at Muc Off but it's bloomin' expensive.
Posted : 25/03/2014 12:51 pm
 Yak
No. Nothing wrong with a bit of water/ cheap car shampoo, elbow grease and a rinse off after.
Posted : 25/03/2014 12:55 pm
I just use a caravan cleaning hose brush and water. Fenwicks FS1 works well but it's not needed really and muc off has been know to cause damage. I'd rather just use water than wash grease and lube out with a chemical cleaner
Posted : 25/03/2014 1:08 pm
Yeah, that's what I thought. They all make claims about protective properties but i'm a bit dubious about if they actually cause damage to some materials. I found the hard way that MRP chain guides don't like GT85 very much.
Saying that, anyone tried - http://ride.io/reviews/ducksmart-cleaning-products-review/
Posted : 25/03/2014 1:21 pm
I blast off any clumps with hose then spray over with mucoff
then go and get a bowl of warm water and give it a once over with a sponge. bit of lube on the seals and job done. comes up a right treat.
Posted : 25/03/2014 1:29 pm
Yes but no the bike specific ones cos they a too dear.
I use http://www.screwfix.com/p/swarfega-oil-grease-remover-5ltr/20817
Check out the dilution ratio... 8)
Posted : 25/03/2014 1:34 pm
This seems to work as well anything else.
[img] https://encrypted-tbn3.gstatic.com/images?q=tbn:ANd9GcQdYcjrFvlFsiqVzfbNo92X0Dri82QSH7OQCRtIy3CuaF90ilPyig [/img]
But
Yak - Member
Probably 🙂
Makes it easier and less messy though. Seem to spend less time on the drivetrain after a quick spray with one of these, so I'm more likely to do it properly.
Posted : 25/03/2014 1:38 pm
Similar to jaffejoffer, but give it a wash with a little car shampoo in warm water after the Muc Off. Dry it off,lube the forks shock and dropper with Fork Juice. Leave it by the radiator in the kitchen to dry then clean and lube the chain. No damage to any of my previous bikes, been using it for years, sometimes three times a week.
Posted : 25/03/2014 1:45 pm
….. and so's your paint!
Posted : 25/03/2014 1:47 pm
 D0NK
fenwicks concentrate for cleaning chains (shake the chain in a bottle)
water and a brush for the bike normally, occasionally use dilute fenwicks if I want to get it properly clean
edit but I think I may be swapping to swarfega thanks patriotpro
Posted : 25/03/2014 1:53 pm
Got given some muck muncher to try.....really rather jolly good. Certainly as good a the pink mucc off and the sh1t shifter
Posted : 25/03/2014 2:00 pm
Yes but no the bike specific ones cos they are too dear.
Wow, 1:50... Homeopathic bike wash?
(I don't doubt it, I use swarfega handwash, great stuff)
Posted : 25/03/2014 2:04 pm
I use golden ale or something similar
after a bottle or two the bike looks clean enough 🙂
I use Hope Sh1t shifter when the bike really needs it with just warm water and a sponge in between.
Our bikes get stripped and lubed regularly so I get chance to clean them up as I go.
Posted : 25/03/2014 3:06 pm
patriot, does that swarfega stuff work well on chain etc and what ratio do you use?
One of the reviews says it was no good at removing the grease even when used neat.
Posted : 25/03/2014 10:26 pm
It's ok if your bike cleaning/maintenance is regular but then I use a proper degreaser for the chain.
The swarfega stuff stuck in an old fenwicks bottle at the recommended dilution is sound for cosmetic cleaning.
Posted : 26/03/2014 12:05 am
I'm a tart so car shampoo / polish on the Inbred - regularly.
I'm nervous about chemicals on carbon so just water.
I use Park Tools lemon degreaser for the chainset.
Posted : 26/03/2014 1:24 am
Awesome stuff, and a quid a bottle.
Posted : 26/03/2014 2:44 am
Car shampoo and warm water normally for me, but I do use Fenwicks too (especially away from home). Always use a proper degreaser and chain cleaner for the drivetrain.
I've got to admit that I give it a wipe down with Bike Spray afterwards. The bike is also bought in the house afterwards to try and dry out any water sitting in places that it shouldn't.
Posted : 26/03/2014 6:10 am
 nikk
Hope Sh%t Shifter works well. One bottle at a fiver lasts a year.
Don't see the point fannying about trying to save £2.50 a year on a multi thousand pound bike by covering it in cheaper stuff that may or may not be suitable.
Posted : 26/03/2014 7:54 am
For the MTB, I hose it off when I get back so the mud doesn't dry. Then dry off the chain and lube so it doesn't rust. Every few weeks I will give the chain a decent clean and lube. Other that that, it generally gets neglected.
Road bike seems to get an oily film on it, I put some chain degreaser on a rag and give the worst bits of the frame a wipe before hosing it off. Chain gets a quick dry/lube.
Neither bikes look showroom but generally all the bits work silently which is all I want.
Posted : 26/03/2014 8:39 am
Let the dirt dry then vacuum it off
Posted : 26/03/2014 8:42 am
Big fan of FS1 neat for cleaning chain & cassette and it watered down to FS10 for the rest of the bike.
Having used Muc Off & Sh!tShifter as well, along with car cleaners & even Fairy liquid I'd say Fenwicks is by far the superior cleaner. Juar wet the bike, spray it on, come back a minute later and hose it off again.
Bike comes up gleaming for very little effort.
Posted : 26/03/2014 8:50 am
I have gone full circle
Car shampoo -> Muc off -> Fenwicks -> car shampoo
Muc off and Fenwicks work, spray on, agitate with brush rinse off. If I had to choose I would say the Fenwicks gave better results.
However a bucket of warm soapy water and a sponge does just as well. I spent a rainy afternoon washing my bikes, cleaning every bit of mud an grease off them before treating the frames with Armourall Shield Wax. It works on the car so thought it might help with the bikes. You can treat a whole bike frame with a thimble full. Now after every ride a quick rinse with the hose has the mud falling of and the water rolling off nicely. Then once a month a wash with car shampoo, a sponge and a bucket of warm water. When away from home one of those hand pump pressure washer things does a decent job rinsing the mud off.
The Fenwicks FS1 does a great job on the chain
Posted : 26/03/2014 10:21 am
I remember some in MBUK yeeears ago about bike cleaners. Started off saying "You may think fairy liquid is just the job, but ingredients can damage your paint and other components. Here we look at some specialist bike products... Make sure you don't leave the Muc-Off on too long, or it can damage you paint and other components..."
M'kay.
hose down and leave for a bit so the mud gets mobile, couple of caps of Flash in mop bucket and have at it with a dustpan-and-brush brush.
Best bike cleany tip I got from here was baby wipes for the drivetrain, quick and easy to use, check your progress by the colour of the wipe. I've also started using them as a final wipe of the paint after cleaning. It's alwasys disappointing to do the final rinse and have it gleaming, look back when it's dry and there's a dull coat of fine swirly muck on the paint.
Makes me sound anal on cleaning. I hardly ever do more than a quick hose off and a wipe of the drivey bits. If there's a perfect storm of perceived need of a proper clean, nice weather and sufficient enthusiasm, I do like to get into it, man, properly dig the process.
Posted : 26/03/2014 10:50 am
baby wipes on your bike? ffs 😆
don't forget to moisturise it too
Posted : 26/03/2014 11:23 am
Baby wipes are awesome. You can literally clean anything off with them, and they work out much cheaper than any other types of cleaning wipes.
Posted : 26/03/2014 11:34 am
Used to use Muc Off but wasn't convinced it was very effective, so now use the hose to remove the big stuff, warm water and a little Auto Glym Car shampoo , rinse and leather dry. I've been using dry lubes for the last 18 months so chain degreasing is very rare nowadays but when required the old jar of petrol and a rag works a treat.
Posted : 26/03/2014 11:46 am
Under £20 for 1000 litres (once diluted to correct level)
http://m.ebay.co.uk/itm/110657541799
(You can buy smaller quantities obviously.)
Basically what MucOff/Fenwicks is but for 1% of the price.
Posted : 26/03/2014 12:45 pm
How often are you washing your bike?
£2.50 a year?
rocketman - Member
For the really stubborn bits, you can use a hammer n chisel too 😆
Posted : 27/03/2014 4:23 pm
 nikk
About once a week.
£2.50 a year?
1 bottle of Hope = about a fiver.
1 bottle of whatever car / hair shampoo you think will save you money, may be about two fifty.
It's just approximate mind.
Posted : 27/03/2014 5:45 pm
About once a week.
On a turbo-trainer?
The Swarfega stuff is £8.09 for 5 litres with a dilution rate of 1:50...
PS - tempted to give stardrops a go for retro-value alone 8)
Posted : 28/03/2014 2:54 pm
 nikk
On a turbo-trainer?
No, outside 5 days a week, was 200 miles last week, mostly off road. Drivechain gets wipe down and lube every day. Bike gets washed once a week.
Posted : 28/03/2014 11:41 pm
I just use car soap and hot water with a brush.
Posted : 28/03/2014 11:44 pm
Zip Wax FTW, 5l bottle from Halfords has been doing me for years.
Posted : 28/03/2014 11:49 pm
Stardrops here as well, and Morgan blue on the chain every now and then
Posted : 28/03/2014 11:52 pm
Everyone should have a snow foam lance in their lives. Awesome on the car and great on the bike too. I try to combine doing them at the same time. It reduces the actual manual cleaning to a minimum reducing dragging around dirty and scratching the finish of painted surfaces (more car specific I guess).
I'm not longer a fan of the complete dunking degrease of the chain if at all possible - just strips too much out of the internals. Best thing for the keeping the drivetrain clean is to take care what you put on it in the first place.
Posted : 29/03/2014 6:57 am
Rhino goo. Wouldn't use anything else.
Posted : 29/03/2014 7:53 am
I stopped using car shampoo. I found there was a suspicious drop in braking performance, and increase in brake squeal after using it.
I'm interested to know how washing up liquid is bad for paint. I always wash my bike with washing up liquid... 😕
Posted : 29/03/2014 7:59 am
Warm water in a bucket and a brush. No hose / pressure. ie not a lot different to what happens when riding. Citrus degreaser on the chain/cassette if it really needs it in winter to get rid of oil clag.
Anything that's designed to clean faster and penetrate under dirt that contains degreasers, salt or whatever is in those spray-ons can also wash into the edges of seals, onto brakes etc isn't so good imo. It's no prob if used sparingly but bearings can wear fast enough as it is without adding that stuff to the mix. A bit grubby on top but mechanically 100% underneath seems to work for me.
Good advice.
Posted : 29/03/2014 8:30 am
 LoCo
Rhino goo followed by rhino shine or cheap car shampoo as always avoid suspension components with cleaning products
Posted : 29/03/2014 8:45 am
As Jameso, although I use a warm water hose on the sprinkle/rose setting so same pressure as rain ! Usually aided by a quick spray of mucoff but not left to penetrate.
Use a park chain cleaner with mucoff in it, 20 backwards revs, top up with water, another 20, rinse, dry, lube. I use gt85 on drivetrain and bolts, silicon spray on shifters and brake levers, fork juice on forks and reverb. A few hrs later (bike lives in dry inside) apply chain lube of choice.
Posted : 29/03/2014 8:55 am
I use Finishline wet all year round, mainly as I have a bloody drawer full of the stuff, and the weather is so wet these days. But it does make the whole drivetrain a bit of a black gooey mess.
....for when it's a bit dryer, what would be good 'proactively cleaning' product for the drivetrain?
Oh, and also use hot water in a bucket with a brush. It is hard to fight the temptation to hose everything off at high pressure to get the job done quicker, tho. Probably why I very rarely clean my bike and just knock the dry mud off.
Posted : 29/03/2014 8:58 am
I find a proper clean and then switch from 'winter lube' to 'summer lube', which for me is Squirt, works a treat as squirt doesn't really pick up dirt and just kinda flakes off. Decent relube before most rides and its ok in the wet for an hr or 2 without reapplying too.
Posted : 29/03/2014 9:21 am
I don't know what I am doing wrong but every bike I've had starts to get a matt finish after a while
It's like something damages the laquer
I've tried brushes, sponges, different car shampoos and bike specific cleaners too
I hose off the bike before I wash it too
Posted : 29/03/2014 9:23 am
Of all the wax lubes I've used Finish Line Teflon Dry seems to lube for longest before the chain goes dry and rattly, chain has to be 100% de-greased + dry before first application tho. I take a small bottle on multi-day rides where I can't clean the drivetrain and need something that will go on and leave a clean chain when worn off. Not great in the wet but not as bad as some other wax-based lubes.
Posted : 29/03/2014 9:26 am
Elbow grease
http://www.ebay.co.uk/itm/2-x-ALL-PURPOSE-DEGREASER-ELBOW-GREASE-TRIGGER-500ml-/290965196803?pt=UK_HomeGarden_CLV_Cleaning_CA&hash=item43bee09003
Best stuff ever, and I have tried a few bike specific ones
Its awesome
Posted : 29/03/2014 9:36 am
Any tips for a cheap and cheerful degreaser? Something like the post above mine?
Posted : 29/03/2014 9:56 am
Jamie - neat Fenwicks or halfords citrus work for me
Posted : 29/03/2014 10:05 am
Bosh! 1l of Fenwicks concentrate ordered.
...and a Ritchey Torque key to put my order over £20 on Evans, so I could use a £5 off voucher. I guess this is why i am not an economist, spending an extra £16 to get a fiver off. 8)
Posted : 29/03/2014 10:21 am
white spirit for chain & cogs, fairy liquid & hot water for everything else. wipe down with wet wipes for the bits you missed, spray with gt85 to disperse water, lube chain etc with oil of your choice.
repeat after every off road ride or couple of weeks for road.
Posted : 29/03/2014 2:56 pm
That's the chain cleaner sorted.
Posted : 30/03/2014 10:48 am
