Bigger cassette wit...
[Closed] Bigger cassette without changing chain?
5 Users
Just put a new chain and front chainring on my road bike, and after a test ride it's slipping a bit on the old cassette. I'm about to order a new one, but I have been thinking about maybe getting to ride in the Alps later this year so maybe it's a good time to get a bigger cassette. At the moment I'm on 50/34, 12/25, which has got me up everything except Hardknott/Wrynose.
If I went 12/27 would I likely get problems with chain being too short?
Posted : 24/03/2015 10:22 am
It would be 1 link difference with the new cassette in the biggest sprocket.
Unless your current set up is very tight for chain length then it would be fine.
Posted : 24/03/2015 10:35 am
You only drop the gearing about 2 inches though
Posted : 24/03/2015 10:37 am
Depends how short you eet up your new chain with your current cassette 2 teeth should be ok failing that sling another link in. Going up to the 27tooth should enable you to climb pretty much anything esp. if your a spinner.
Do you still have the spare links from the chain? If it's still new, put a few links back in with a quicklink.
Posted : 24/03/2015 11:57 am
