I know the motto buy cheap buy twice. Purchased one of the on one xc helmets (the fox flux rip offs) a couple of years ago. Don't wear it much - only when it's hot as it's nice and light and well vented. So today the helmet strap just parted near the tongue of tongue and buckle. The helmet comes with a velcro chin guard that raps round this part of the strap and is a sweat sponge which leads to the actual strap rotting away. So check your strap and ditch the chin guard.
What inexpensive well vented helmet for summer ?
Surely that's not just limited to the On-One though is it?
Any chin strap that's soaked in sweat will rot at some point.
Take a close look at that strap. You'll see no evidence of rotting.
That strap has been cut by the sharp moulding plastic of the buckle.
I wonder if people will be making excuses for OO’s horrific quality control with these helmets the same way they did for the frames?
Never seen anything like that and I'm not shy of sweating a bit
@scienceofficer - never had a strap break on any other helmet - the only difference between all my previous helmets and this one was the velcro chin guard. I presume the sweat weakened it enough for the buckle to do it's work.
@dirkpitt74 - never had any other helmet fail at the strap ever.
I mean that is cheap - you could buy 1 a year and always have a nice fresh helmet.
I don't think nylon rots, and most likely this end of the chin strap had two loose ends from the beginning. As can be seen in other images of the helmet, it is the other side of the buckle that has the strap looping through it.
In short, nothing broke; just burn/melt the ends a bit to stop further fraying and feed them both them through the buckle. Good as new!
Yeah that is cut not rotted, I'd be sending the pics to on one right now as a PSA really
Next door neighbour has the enduro helmet. The stitching has failed at the helmet (anchor point)end.
I had compression straps cut through with Thier buckles like that.
@otsdr - you are correct - there are two loose ends where you adjust the fit of the strap. However part of one of the straps has sheared off because the helmet no longer fits - the straps are now not long enough -though they were fine when i set off. The failure happened when i was cycling and i didn't notice that part of the strap had sheared of. I was lucky to find the tongue. One of the straps is now considerably shorter than the other which doesnt show so well on the photo. Sorry for any confusion.
I’m not sure sure I understand?
Isnt that just the ends of the straps being a bit frayed? Melt with a bit of heat and it’s sorted?
I can't understand this. It makes no sense.
Are you saying there is nothing wrong with the helmet?
Got 3 PX/O-O helmets, all seeing pretty good usage. No issues with straps - just checked them all, just in case xD
Maybe, you just get dodgy one?
Cheers!
I.
As I read it one of the straps has been cut through by the buckle. The helmet is no longer usable as there is not enough strap left to fit the buckle in the correct position.
surely what's happened there is that the two fabric straps from the front and back of one side have come out of the adjustable buckle?
The female part of the buckle looks fixed length, the male part has has both staps through and back and the chin sleeve is there just to stop the straps flapping and chaffing your throat.
That's perfectly normal. you havent kept an eye on the straps as they do have a tendency to wander on any helmet, or you've got them too long.
in fact here's a Giro and a Cratoni from the shed with exactly the same design.
Have you owned a helmet before? or indeed all the others so quick to flame before thinking things through...
I bought one of the Carnac helmets from On One last week. It burned down my shed, beat up Mrs F and turned Funk Jr and Funkette in to criminals. I’ll be penning a sternly worded letter to On One about this I can tell you. Not even worn it yet and it’s pretty much ruined my life!
Just looked at mine, and I’m now convinced there is nothing wrong with yours.
Adjust the straps and thread them back through the buckle. Cig lighter or candle on the ends to stop them fraying and you’re done.
Mans in future, try not to overreact when the buckle slides off the end of your helmet straps 😂👍
@funkmasterp Can I buy your helmet please? Sounds like the ideal early Xmas present for my daughter's boyfriend.😉
I'm still not sure I understand the OP's issue?
Has a strap snapped or been cut through, or simply slipped out of the buckle?
@Neal Glover To clarify - part of the strap has sheared off where it goes through the buckle. Because part of the strap has sheared off the strap cannot be fastened. The strap is no longer long enough to fit unless i saw several inches off my chin. @rubber buccaneer has got it. I've binned the helmet as it no longer fits. As it sheared off with no warning that,s why i posted.
Not defending anyone here, but when the Bontrager Rally came out I bought one I'd tried it on in the shop, got it home and thats when I noticed that the chin strap hadn't actually been attached to the plastic divider below the ear, so even the really big companies have crappy QC, and still haven't heard back from Trek, but Evans sorted it straight away.
Just thought it a bit off that part of the strap should shear off where it went through the buckle. Binned it now as it no longer fits and even if it did my trust in it is not very high. Up till today it's been fine. I noticed on ebay that a chinese company BAT Fox have bought out a knockoff of the new fox flux so now doubt that will appear on on one one day as their current offerings are homages to the original fox flux (XC) and Enduro (POC) Decided my head is worth more than £14.99 so ordered a Specialized Ambush comp that i can pick up on wednesday.
So to support the claim of a plastic buckle cutting cleanly through nylon webbing* we get one photo that's at best completely inconclusive and then the item is binned? No more photos, no sending it to the supplier for inspection of this critical and extremely unusual alleged safety flaw?
* or the original claim of nylon rotting prior to someone gifting the OP a less obviously bogus explanation
By the way, you can see the creases where the buckle was originally located on the strap. There are two pairs of them, respectively about an inch and two inches from the end of the strap nearest the camera. Conversely, there is no creasing at the ends of the straps where the buckle is alleged to have cut the strap. For a cut to have been made, it would have to be where the strap passed over a sharp edge on the buckle, and there would be creasing as a result. Additionally a cut would normally need a decent amount of tension in the strap, but there's no evidence of tearing or similar: the ends are both perfectly square.
So if you ask me, all the evidence in that photo points to a buckle that's slipped off the end of straps; the only manufacturing "flaw" I'm seeing is that the straps appear to have been left as a raw cut rather than melted.
I'd fish it out of the bin and have another go at reassembling it. But if you don't fancy that, fish it out of the bin and try cutting that nylon webbing with a kitchen knife and, once you've had a go at that, have a think about whether the plastic buckle would get through it, let alone do the clean, squared-off job you think it has…
Obviously completely up to the op what they do, but afraid I'm in agreement with the doubters - the 'cut' looks far to clean, if it had cut I'd expect a far more frayed end to the strap, it looks far too clean. I'd suggest the straps need readjusting. How is the strap fitted? Is it a single piece or multiple straps?
Personally, I'd ditch the chin wrap, that would just annoy me as it got soggy.
for pity's sake what is wrong with you?
There is nothing that has sheared. Nothing has rotted. Nothing has failed here except your ability to adult properly.
You've junked a perfectly good helmet because you cant re-fit a buckle to straps?
Stoner is right. There's nothing broken there. The buckle has just come off the end of the two webbing straps. Both straps should pass through the buckle, laying flat together.
for pity’s sake what is wrong with you?
I got a similar lid from PX. Came looking a bit like that. I trimmed the (excessively long) webbing tails with a hot knife and threw away the velcro pad.
and another poster with a 'not really a problem' problem returns to the classifieds pages.
But OP says that strap is now too short (unless he cuts part of his chin off - which admittidly does have some comedy value)
Certainly nothing looks wrong, except statements like "it no longer fits" - has it changed size?
This is almost as good as crack/sticker-gate 🙂
Ive got a crisp fiver that says the OP just hasn't put it back together properly 😉
Which bit do you mean? The half a clip that, [as it broke] whilst riding, would have been inserted in the other half a clip so a doddle to find or is there some other bit I'm not envisaging?
Possibly OP is putting helmet on back to front, hence why it no longer fits
The OP mulling over why his helmet no longer fits
To be fair £15 is an absolute bargain, might get one myself.
I’ve just ordered one. Look good for the price 👍
the OP also said that his sweat had “rotted” a nylon strap (a strap is clearly not rotted)
And that a plastic buckle had “sheared through” a piece of nylon webbing (that you would struggle to cut cleanly with a decent pair of scissors)
So im just ignoring the rest of it.
The buckle came off the end of the straps, and just needed re threading.
The OP has binned a perfectly funtioning helmet due to not understanding how things work
Looks like sabotage .........you been shagging out of watch ?
Wait til he sees what it's done to the EPS !
This thread reminds me of the STW of old.
A) i am quite capable of adjusting a strap .
B) I suggested it had rotted, because the only difference between this helmet and other helmets i have owned was the chin guard which was acting like a sweat sponge and the straps were soaking wet.
C) Bez - the so called creases are sweat and dirt marks, so you owe me a fiver.
Wait til he sees what it’s done to the EPS !
You mean absolutely nothing?
<div class="bbp-reply-author">bobgarrod
<div class="bbp-author-role">
<div class="">Member</div>
</div>
</div>
<div class="bbp-reply-content">A) i am quite capable of adjusting a strap .
</div>
Your evidence suggests otherwise!
C) Bez – the so called creases are sweat and dirt marks, so you owe me a fiver.
Well, you're the first person I've come across who sweats in equidistant parallel lines.
They appear just as indentations from the buckle normally do: you can see how the weave of the mesh curves differently.
Where are the bits that have come off? There will be two separate straps so they'll both have 'ends' on them?
Funny how it didn't rot if that's the case.
Dig it out of the bin OP. Take a photo of the complete helmet straps and all. Only way to tell whats going on and to vindicate your self 👍
This is amazing. Why can’t he put the buckle back on the straps?
I can’t work out what he thinks is wrong.
The only thing I wonder is if the adjustable buckle where the front and back straps join, usually at the ear, has moved and shortened the straps in a weird way?
A) You’ve thrown away a perfectly good helmet
B) You’ve thrown away a perfectly good helmet
C) You’ve thrown away a perfectly good helmet
(edit- if you manage to get the fiver off Bez though, your a third of the way to replacing the perfectly good helmet you threw away 🤪)
My lawn has died and I own an On One.
The bastards.
According to the OP (who is the only one to have seen and touched the helmet) the strap snapped at the joint with the buckle..
Maybe we're all getting this all wrong. Re-reading the thread title in the context of the thread, maybe the OP is imploring us to be wary of people who own On-One helmets 🙂
One in particular.
I’ve an old helmet strap that’s been supporting my rotary washing line for 3 years, come rain, come shine. Apart from fading somewhat, it’s still robust and functional. Maybe we need more acid rain for a proper comparison, but that strap has either been cut by a loony or maybe pulled through (same strap does both sides of helmet clip on my Giro lid)
Please get the helmet out of the bin OP and post pictures of it up on here?
Just be careful you don't cut your hand on the buckle...
My lawn has died
Are you sure it didn't get wet and the grass accidentally got cut off by a buckle?
thread title was quite prophetic
Glad I saw this thread, reminds me i have 2 on-one helmets sitting in my basket that i never got round to ordering.
Don’t do it davey! Have you learned nothing of the dangerous world of nylon and plastic from reading this thread. On your head be it (if the straps don’t break).
I've just been out to check my Saris Bones bike rack as it uses nylon straps and god forbid steel buckles but thankfully absolutely no evidence of wear. I think I'll take a punt on those lids for that price.
Yeah but you probably don't sweat much on your bike rack, and it's the sweat that rots the straps!
I'd like to nominate this as a Sticky thread so that when the English school holidays start, the kids can see how best to behave on this forum...this is classic school kids on holidays material!
Ah ok i get it. Thing is it's been on the car since last summer and through the winter it got caked in road salt regularly but maybe thats different. Thing is nylon is a pretty hardy material that's why they use it.
and it’s the sweat that rots the straps!
No. It really doesn't.
Check your irony detector 😉
Has the OP been back - or will this be like the incessant snow thread...
No. It really doesn’t.
I knew i should have added a 😉
I was assuming he's been trying to get online to respond but his mouse has sliced through his broadband cable.
I was assuming he’s been trying to get online to respond but his mouse has sliced through his broadband cable.
Fortunately my keyboard is wireless, otherwise the tea i just spat on it would have rotted through the connection and I wouldn't be able to congratulate Bez on this response.
I’ve just been out to check my Saris Bones bike rack as it uses nylon straps and god forbid steel buckles but thankfully absolutely no evidence of wear. I think I’ll take a punt on those lids for that price.
Steel or plastic shouldn't really make any difference, both are harder than nylon.
From the photo's I don't see how anyone can say what happened... except that it's not sweat but that doesn't mean the straps didn't get cut over time by a sharp edge to the clip...
I've no idea what the differences are between the same shell from Fox and the same shell from on-one or anyone else.. but assuming the helmet is the same shell I wouldn't be at all surprised if the cheaper copies used cheaper plastic clips and that some might just have sharp edges from the moulding.
As a parallel....
I just picked up one of the SJ CAM's from Amazon... at £30 the stuff that comes with it would cost more if it was genuine GoPro... but the plastic mouldings and such are of far inferior quality and QA. There is a cute little clip/stand with inserts for a tripod adapter top and bottom... the top one is a bit unusable as you then can't get to the buttons and the bottom one hasn't been threaded properly... but been inserted anyway. The actual part SDCAM make (the camera) is excellent for the price... however the screws don't work as well, the non waterproof clip has an issue etc. otherwise its probably better than a GoProX (whatever old version that is) except the peripheral/extra bits
Of course the dodgy screws and missing thread are not protecting my head...
I'm sure if you bought 100 out of those you'd find similar QA issues in way more than official but 10x the price GoPro... so I wouldn't be surprised to see the same with helmet "additions"....
From the photo’s I don’t see how anyone can say what happened…
I’d say it’s fairly obvious.
The clip came off the end of the strap, which had frayed a bit, leading the op to believe something catastrophic had happened, and he jerked his knee all the way to the bin and then to the keyboard.
Sadly it was bin day, so he couldn’t get his perfectly good helmet back.
And its even more obvious what didn’t happen. (All the stuff the op said had happened)
OP, was there a little rubber O-ring anywhere when your strap and buckle separated?
There's normally one fitted these days on most lids as a measure to help stop the straps loosening...
Steel or plastic shouldn’t really make any difference, both are harder than nylon.
Although it's highly likely that the buckle is nylon 🙂
(Different forms, of course. The webbing fibres will have a hardness of around 30D and the buckle around 80D.)
The OP also forgot other solutions are available:
I don't see how the clip can come off the end in use.... if the helmet is remotely the right size ...???
All my helmets either have straps where the end is folded and stitched down (and can't come off) or has 2-3" of extra strap .. with the ear parts adjusted ... even when I wear a helmet a bit too small (I once packed the kids helmet which I can just squeeze into at maximum adjustment) there is so much strap it can't come off in actual use (as opposed to playing out with the helmet off).
All my helmets either have straps where the end is folded and stitched down (and can’t come off) or has 2-3″ of extra strap
Cool story. Was this one of your helmets ?
(If it was, it’s in the bin now) 😂👍
