What are the best solutions out there?
Thanks
Richard
drill holes through the door and into the surrounding brick work then use metal pegs to secure. simple and works.
I put a padlock through a hole in the door runner / rail so that the door only opens a small distance.
You obviously need to be to lock the door from the inside though.
Yep that's what I was advised to do by the polis after my garage was done.
They said the scrotes expect to be able to peel the door up with a crow bar so you do the drilling quite low down so they can't crawl under any space they can make
the problem is that the doors are actually pretty weak - a crowbar is enough to bend them enough to get in (though maybe not enough to easily get a bike out) so locking the runner doesn't really help.
me too - and I've got metal shelf-rails jammed in each side at the botom stopping the swingarms from moving outwardsI put a padlock through a hole in the door runner / rail so that the door only opens a small distance.
Park the car in front of it.
Brick it up and put something in there that's fit for purpose..
[url= http://www.directlocks.co.uk/asec-garage-door-bolts-pair-garage-door-locks-p-1133.html ]Asec Garage door Bolts[/url]
Aristotle has the answer.
Access from both sides of the door rather than a padlock on the inside or a steel rod put into a hole, again, from the inside. The OP might not have any other door to the inside of the garage.
Jamie's reply is a bit weak, does he really think if some scrote thats prepared to damage a door and steal a bike is going to worry about smashing a car window and letting the handbrake off. 🙄
