As Cannock has turned into a muddy gritty mess I need something to keep my chain and cassette in good nick. Anybody got any tips or products they use? Oh, and whats the best chain oil / Lube out ATM
Thanks in advance
I use pedros extra dry at cannock/woburn etc where its sandy
Is it a C90?
many discussions on here about it and you will get many different replies.
[url= http://www.putoline.com/en/products/catalogue/segp_offroad/pchmp/559/off-road/chain-maintenance-products/chain-wax/ ]Putoline chain wax[/url] for me - last ages on the chain. cheap, works well and if you wipe the chain down after application the chains and cassette remain clean
Fenwicks foamy goo for cleaning
http://fenwicks.info/fenwicks-fs-foaming-degreaser.html
"best lube" is very subjective, the best I've ever tried is the chain-L 5, but it is best applied to a new chain (or at least a fully degreased and dried chain)
http://www.chain-l.com/
Chains are like underpants; new ones are nice, but most of the time you'll be using older, more worn ones. Despite the advent of chain wear checkers, and all the associated BS, you will wear them out and you will have to change them.
Best bet; use a dry waxy chain lube.
Why?
It's less hassle to clean when it's dry.
When it's wet, you don't need a chain lube because water does an excellent job.
Singlespeed it & leave the gears off till summer. You'll probably find you need less of them when you put them back on again. 🙂
dont ride it
