Best way to cut a c...
[Closed] Best way to cut a cable lock?
11 Users
First time for everything, I guess 🙁
Yep.. locked up bike and lost the key!
Tried hacksaw, no jpy.
Only about half-inch thickness--twisted thin layers of steel.
Just after quickest/easiest way with minimal faff..
Posted : 04/12/2017 9:33 pm
 core
Side cutters
Posted : 04/12/2017 9:34 pm
Asking for a friend? 😉
Posted : 04/12/2017 9:35 pm
Ask the local chavs to sort it for you.....
Otherwise angle grinder
 ton
large boltcrops.
Posted : 04/12/2017 9:41 pm
As Ton says
or battery angle grinder (2 second job) - stretch it across a block of wood
Also possible to put a bottle jack inside and pull it apart if its short enough
Posted : 04/12/2017 10:01 pm
Fiskars X27
Posted : 04/12/2017 10:02 pm
junior hacksaw took about 10seconds when I had to...
Posted : 04/12/2017 10:29 pm
Large boltcrops will be the quietest. 14v angle grinder will be the quickest.
Posted : 04/12/2017 10:59 pm
Hacksaw is surprisingly tricky on cheap ones, because it binds up. If it's a half inch, there's a decent chance you could cut it with kitchen scissors
Posted : 04/12/2017 11:00 pm
Just give it a sharp tug.
As this article says, "never, ever use a cable lock".
http://thebestbikelock.com/best-bike-lock/who-is-trying-to-steal-your-bike/
Posted : 04/12/2017 11:08 pm
If it were me and I had the problem locked at home I'd be getting an angle grinder on it.
Posted : 05/12/2017 8:04 am
