I have a single bottle cage mount on one of my bikes.
I’d like to use the bike for longer rides that unfortunately don’t have any refill opportunities en route.
Yes, I could wear a solution but I prefer to ride without anything on my back or waist.
There appear to be loads of options for attaching “things” to a frame. Are there any recommendations for which work best?
I’ve had these on two bikes and they were both completely fit and forget. Tape underneath them if you like you paint unscuffed.
Is filtering water an option?
I bought a water-to-go filter bottle after a recommendation on here. I've used it loads on longer rides. It's a bit of a game changer.
I wouldn't filter any old water, but I've used it a lot from small streams up on the moors/tops away from farms and never had a problem at all.
I've used a rubber mount (from Decathlon) that worked well attached to the forks of my Fatbike.
However, the Water-to-go bottle is now my regular carry on such rides.
Those Decathlon bolt on mounts are pretty nice, but maybe not so sturdy if you're riding rough terrain.
How about a stem bag? Easy to access the bottle and to remove from the bike when you don't need it.
I've used:
Frame bag with bladder
Handle bar bag with bottle
Topeak zip tie on bottle cage mounts. https://www.topeak.com/global/en/product/1093-VERSAMOUNT
For loads of water- frame bag and bladder. Mine is 2l
For one bottle the topeak zip tie on bottle mount works exact as a bottle cage.
I use one of these to give me a 2nd bottle on my FS mtb and a third bottle on my cross/gravel bike.
Topek also do a bottle cage mount that fits 22mm bars, gives you the option to add another bottle cage or two on the bars.
Have also used some of those zip tie on types before and all good.
James
I know you said on the bike, but how about two 250ml soft water bottles on the back pockets. Drink them first and they weigh nothing. Thats what I do when needing to take extra water.
