The terminals on the batts and the lights look a bit dodgy - any decent tapes out there which last longer than insulating tape in the rain.
[url= http://www.toolstation.com/shop/p23876 ]Self amalgamation tape[/url] bonds over time into a solid block apparently, repaired one of my lights by building it up so that the 'turn' in the cable wasn't so close to the connector (that link was the 1st I found, the stuff I used was only about 10mm wide)
Worth considering some better [url= http://www.ebay.co.uk/itm/141060200785?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT ]Connectors[/url] the waterproof seal would help alleviate the issue in the future, remember you also need a set for the charger
brilliant thanks - the bodge and the best solution in one post.
The terminals on my solar storm head unit worked loose around a year ago,although the connection inside the unit remained intact it would have been a matter of time before it stopped working.
Two dollops of [url= http://sugru.com ]sugru[/url] around the terminal sorted it and its been perfect since.
Is that surgru as good as it looks?
