Soapy water - didn't even touch it
Meths - nadda
White Spirit - removed a few balls of loose gunk, but barely touched it.
Petrol (well, 100:1 2t mix as it's all I had) - worked, but still too 15 minutes to clean a seatstay with a microfibre cloth.
a) WTF is this stuff that peels off when you don't want it to, but is as sticky as a wrapperless week old boiled sweet left in the car.
b) What gets rid of it? Would a green scouring pad mark the paint if used in conjunction with petrol?
A scouring pad will probably mark the paint. You might need a dedicated glue removal product like Autosmart Tardis.
Heating it up a little helps- it tends to roll off when warm. Either that or actually soaking it in isopropyl- not just wiping with a cloth but soaking a rag and leaving it on the bike for a while.
Gt85 .. Wd40 etc work well 🙂
Try nail polish remover, usually works with the sticky gunk off most decals and safety stickers!
Tar and glue remover works a treat , just watch out for the fumes 🙂
Halfords citrus aerosol degreaser...great stuff for removing helicopter tape residue and other household stains
I've had success with Mr Sheen polish, it usually works a treat.
WD40
Petrol, or disc brake cleaner for me. Baby wipes to finish off.
Maplin do a label remover, which is a good solvent, should get it off, about £3.50 for an aerosol....
Nail polish remover has never failed yet .... on anything bike muck related ..
car bug/tar remover
WD40
Both should do the trick if you let them sit for a while
Regards, Paul
Lighter fluid.
