best GPS for naviga...
[Closed] best GPS for navigating singletrack?
3 Users
I've been using a Garmin Edge 205 for a few years now mainly to record rides that I go on led by others, or to follow rides that I've downloaded from Garmin Connect, Strava etc.
Trouble is, when following a course on the Garmin, it doesn't show any arrows on the line you're following, and if it's a ride that criss-crosses about a lot in a small area, it gets very confusing. Garmin will argue that a course is not intended as a navigation tool, so they're not interested in solving my problem.
Does anyone know whether the more expensive Garmins or their competitors get round this problem? Or is there a feature I'm simply missing? Some people have suggested switching to compass mode but I don't really find that useful, I want to have some advance notice of where the trails's going, with arrows to show the direction. Any ideas?
Posted : 27/11/2012 2:40 pm
I've had an Edge 305 and an Etrex and you don't get arrows on the screen as such. With the newer models you can set it as a route and then it will follow the sequence of waypoints but then sometimes thinks you've taken a short cut if you cross a path and bumps you a few waypoints along.
To be fair, I don't ride many routes where it continually criss crosses.
I do the odd figure of 8 where I split the .crs file or route into 2 to avoid confusion. If the course only crosses the same point once or twice, your easiest option would be to split it into separate courses.
Posted : 27/11/2012 3:03 pm
you need to set waypoints and store as a route not a course. It'll do the arrow thing then.
Posted : 27/11/2012 3:05 pm
