Best chain lube (wh...
[Closed] Best chain lube (which doesn't gunk up?)
84 Users
Hi all,
Any suggestions for a chain lube which avoids turning everything into a filthy black sludge? I use a standard wet lube but after a week or two the chainset is filthy.
Posted : 05/01/2020 8:18 pm
Finish Line dry is still my go to. You’ll need to reapply more regularly but it’s not too mucky.
Posted : 05/01/2020 8:21 pm
Peatys... Formerly wickens and soderstrom is easily the best lube I've ever used.
Road cc did a review of the w&s version and peatys is pretty much the same
https://road.cc/content/review/177819-wickens-soderstrom-no5-drivetrain-lubricant
Posted : 05/01/2020 8:22 pm
Squirt lube
Posted : 05/01/2020 8:23 pm
Squirt.
Heard that Smoove is better, which I'll be trying when my current bottle of squirt runs out.
Posted : 05/01/2020 8:24 pm
Mucoff dry works well for me - needs reapplying a lot more regularly but I’ve found I can just run the chain through a couple of wet wipes and reapply no probs...
Posted : 05/01/2020 8:27 pm
+1 squirt
On a bottle of Smoove at the moment which is pretty good but I think squirt just edges it.
Posted : 05/01/2020 8:29 pm
Squirt
Posted : 05/01/2020 8:30 pm
Squirt for me on the mtb and summer roadie. Been using the Peaty's stuff on the winter roadie this year and seems to be working pretty, though I'm going through it quite quickly.
Another for Squirt. I got a small bottle of smoove free with an order a while ago and it's good, but bought a bigger bottle of squirt, use it on both MTB and gravel bike.
Posted : 05/01/2020 8:32 pm
Pedro's Syn lube is gunk free. I usually jetwash the chain afterwards comes, up as clean as a whistle.. then zap it with GT 85 before re-lubing it...
https://boeshield.com/bike/
Posted : 05/01/2020 8:35 pm
putoline motorcycle chain wax. so much cheaper and so much better than cycle lubes its not funny.
A faff to apply but it doesn't need doing often and your chain life will be many times as long
Posted : 05/01/2020 8:42 pm
Mucoff dry or wet. Wipe clean chain after washing bike. Apply lube. Leave on chain as long as possible. Wipe chain as dry as you can get it. Go ride and repeat. Works for me.
Posted : 05/01/2020 8:51 pm
I'm on Juice Lubes Viking, best non gunky I've tried.
Posted : 05/01/2020 8:57 pm
I didn’t like Muckoff standard wet line - gets really gunky really quickly.
Their standard dry lube is better -
It goes on white and kind of waxy but doesn’t seem to attract loads of dirt. Probably doesn’t last as long as wet lubes in the wet mud though.
Posted : 05/01/2020 9:02 pm
Morgan Blue extra dry lube in aerosol format is my current favourite
Posted : 05/01/2020 9:04 pm
I used to use Squirt in dryer conditions and Putoline in wet conditions.
I switched to Smoove one summer and found it better than Squirt, especially when getting caught in the wet. In fact, it worked so well, I didn't bother going back to Putoline.
Posted : 05/01/2020 9:06 pm
+1 here for Squirt. Used it for years even in wet conditions. As long as you do a really thorough degrease of your chain once the factory lube has worked its way through, Squirt sticks just fine.
Posted : 05/01/2020 9:13 pm
+1 for Squirt, there is also a low temp version for colder temps
Posted : 05/01/2020 9:20 pm
I hear lots about Squirt. What are the costs of using it as I hear you need to lather it on like KY Jelly in the Sahara?
Posted : 05/01/2020 10:15 pm
+1 for Boeshield T-9, I'm happy with it.
Having said that I've never tried Squirt, but after all the recs here I think I'll give it a go.
Posted : 05/01/2020 10:17 pm
Just moved to Putoline also.
Screwfix degreaser to clean the chain then a Putoline chain wax treatment.
Plan to do it every three months and see how I go.
Posted : 05/01/2020 10:20 pm
Another vote for juice lubes Viking here, works well in South Downs conditions.
Posted : 05/01/2020 10:21 pm
I’m just finishing a bottle of the wickens and soderstrom which is good in the slop. Will either move into the Peaty’s or may try squirt. CBA with the plutoline.
Posted : 05/01/2020 10:25 pm
Mucoff ceramic for me.
I think I may give motorbike chain wax / putoline a go next.
Posted : 05/01/2020 10:42 pm
“putoline motorcycle chain wax. so much cheaper and so much better than cycle lubes its not funny.
A faff to apply but it doesn’t need doing often and your chain life will be many times as long”
TJ kindly offered to Putoline a chain for me but I never got around to sending him one and bought a tin of it and a £15 mini deep fat fryer to melt it. It’s bloody brilliant! I did three chains at once and intend to swap to a fresh one every month or two and then rewax the lot.
I commute and MTB on my ebike and with normal lube it eats drivetrains so fast, but from the sound and smoothness when pedalling post Putoline I’m very hopeful.
Posted : 05/01/2020 11:12 pm
Squirt lasts very well as long as it's applied to a throughly cleaned chain.
Posted : 05/01/2020 11:27 pm
+1 for putoline, it’s in a different league to any bicycle specific ‘lube’.
Bit of a faff to apply, but well worth it from that moment on.
One tin will last years and years, at the very least.
My MCopinion: if you think anything else is better, you haven’t tried this.
Posted : 05/01/2020 11:39 pm
I think the takeaway from all these types of threads, is the advice: clean and lube your chain frequently (at least after every off road ride) with a chain lube that you'll continue to use (because of whatever reason is important to you), is the best method of extending your drivetrain life-span.
Posted : 06/01/2020 6:43 am
Squirt, the low temp one when it's under 5deg C as the carrier evaporates quicker, so the wax lube dries quicker.
Clean, lasts brilliantly and chains seem to last longer too
Posted : 06/01/2020 7:03 am
 P20
This has finally triggered me to buy the Plutoline for the commuter. Might stick with something more conventional /quick for the rest of the bikes
Posted : 06/01/2020 8:43 am
Muc off wet is the worst for gunking up. Makes a black sludge that sets like tar.
I'm using Fenwicks professional at the moment. Needs applying to each roller individually but only takes a few minutes. Doesn't gunk up and lasts well.
Posted : 06/01/2020 9:10 am
To the Squirt users - do you use it year round? I used it in the dry(er) months, but was advised to use something else in the winter so opted for Extreme Blue.
Posted : 06/01/2020 9:18 am
Wilco's wet lube. Was an emergency buy one day, didn't expect much much but really surprised by how good it is.
Posted : 06/01/2020 9:21 am
“This has finally triggered me to buy the Plutoline for the commuter. Might stick with something more conventional /quick for the rest of the bikes”
Doing lots of chains takes no more time than doing one, you put them all in together.
Posted : 06/01/2020 9:24 am
+1, and id agree with the comment that if you think something is better, you've not tried putoline.
Its a whole different ballgame.
nickc
Subscriber
I think the takeaway from all these types of threads, is the advice: clean and lube your chain frequently (at least after every off road ride) with a chain lube that you’ll continue to use (because of whatever reason is important to you), is the best method of extending your drivetrain life-span.
Except for putoline, when realistically its 500+ miles in the dry, and a lot longer than any liquid applied lube in the wet. I think my CX bike is currently doing worst at 100 (filthy) mile intervals.
Its on the same sort of frequency as brake pads!
The side benefit of longer lasting drivechains is simply a function of how long the wax lasts. Putoline almost always lasts >1 ride, even in the worst conditions on a long ride. It has to be utterly horrific to wash it out. So most of the time iy lasts weeks/months.
How often do you hose your bike down after a ride and come back the next morning to a rusty chain (indicating that at least some of the last ride was without lube).
Posted : 06/01/2020 9:38 am
The wax lubes are always the best option but the likes of putoline come with extra faff of the application that I can never be bothered with TBF.
I never have a rusty chain as I'm a bit anal about washing and reapplication which I'm aware is probs as faffy as the occasional putoline application, but at least with the benefit of not having to remove and refit a chain or melt a tin of wax on a stove. This time of year I'm only using the MTB once a week anyway, so it's not the end of the world to drop some lube on the chain after washing it.
Like I said, the best lube is the one you put on your chain regularly
Posted : 06/01/2020 9:47 am
That doesn't sound so great. Realise it is the extreme short end but a lot of difference between one ride in worst conditions and the people claiming 3 months?
I just use dry lube as the wet lubes makes a mess. I put a new chain on in Spring so I have it at it's best in drier months then by end of winter it needs replacing. I get 2,000+ miles out of a chain riding in all weather (a lot of gritty, wet gravel) and just lube eery other ride.
This is all single speed though so guessing that is why they last so long as not chain not being continually put at angles.
Putoline also. Ridiculously tenacious and not at all sticky.
I've done my MTB every month or so in the current filth, and when I get home from a muddy ride I just hose my bike off, put it in the garage and it's spotless and ready to ride.
It really is a game changer, if you'll excuse the phrase.
And it's really not a long process. 5 mins for the fryer to heat up, dunk it, waggle it around a bit, then hang it up to cool down. I give mine a wipe when it's cooled down enough to handle and get the stuff off the outside.
Posted : 06/01/2020 10:13 am
That doesn’t sound so great. Realise it is the extreme short end but a lot of difference between one ride in worst conditions and the people claiming 3 months?
For me it's been 4-6 rides in the absolute filthiest conditions, meaning streams running down the climbs and wellie-losing mud patch type conditions. It probably didn't need doing again, I was just playing safe. It has stayed silent and smooth the whole time.
I'm not being paid by Putoline. I've tried most lubes in 25 years of biking and sure, some are a bit better than others. But Putoline is a completely different ball game.
Posted : 06/01/2020 10:16 am
No mention of Rock n Roll Extreme yet?
That's been my go-to for years and I still love it.
I had one bad batch where it didn't have enough solids in it, but recently it's been back up to form.
Needs doing every ride in wet winters and costs quite a bit, but my chain is always clean, runs smoothly and seems to last longer than expected.
Posted : 06/01/2020 10:19 am
I’m not being paid by Putoline. I’ve tried most lubes in 25 years of biking and sure, some are a bit better than others. But Putoline is a completely different ball game.
Will probably give it a go next year with new chain.
Posted : 06/01/2020 10:23 am
Acidic soils with sand ie peat will strip the putoline out. Its the only conditions I have found that will and then only in extremis.
I get thousands of road miles and hundreds off off road miles out of each application and also have the benefit of always having a well lubed chain and it does not collect on the cassette or attract dirt ( beyond and initial coating of dust)
This chain has done half a dozen rides, still well lubed, no buildup
[url= https://live.staticflickr.com/65535/49338785312_4d0cbe6e8b_k.jp g" target="_blank">https://live.staticflickr.com/65535/49338785312_4d0cbe6e8b_k.jp g"/> [/img][/url][url= https://flic.kr/p/2iaUaWh ]IMG_1265[/url] by [url= https://www.flickr.com/photos/25846484@N04/ ]TandemJeremy[/url], on Flickr
Posted : 06/01/2020 10:29 am
I think its different if your riding/ commuting daily or a weekend warrior.
For the later, after I get home I wash my bike, let it dry in the sun, then spray the drivechain with GT85 to expel water and lubricate it and a loose wipe the excess off with an old towel snf clean the chainring(s). Then put it back in the room. The following week or so, before I ride I spray it with GT85 again immediately before I ride and wipe off the excess. No noise, no rust, shiny, no wear fabulous changes, no 'de gunking' or chain removal.
Its a light oil that doen't hold crud, gets in between links and lasts 'long enough' on a day ride. When you wash it off, it's not heavy enough to stick on so the crud comes off and you don't build up the residue that wears your drivetrain. Its the sweet spot for me between lubrication and not dealing with build up or application hassle.
Muc off wet lube does leave a black gunky mess for sure. Never again. The Muc Off Dry lube put on the links individually, is excellent, just gets a bit pricy if you use it frequently. I prefer just GT85 spray, about £2 a tin. Worked for me for 30 years.
If I was commuting, I'd likely want more 'lube and forget' stuff that hangs around longer. Not tried the Putoline or Squirt, so maybe I'm missing out.
Posted : 06/01/2020 10:48 am
+1 for putoline here too. Just started experimenting with the DIY candle wax methods as well.
Posted : 06/01/2020 11:01 am
been using Squirt for a while now but it doesn't hang around as long as id like in the current conditions... returned to a rusty chain a few times over the last few weeks!
certainly never any gunk tho.
Posted : 06/01/2020 11:36 am
Is Putoline any better than Molten Speed Wax?
I've been using MSW on my summer road bike in dry conditions for 18 months and been relatively happy. There's a little more drivetrain noise than when using liquid lubes, but it's acceptable.
I get 300-400kms out of each chain wax before it needs redoing, and I wax/rotate 3 chains simultaneously, therefore I'm only having to cook/wax once per month.
However, with MSW it's a very different story when it comes to rain/wet and winter conditions:
after just 1 wet ride rust discolouration starts to develop on the surface of the chain, and the chain becomes noisy. I've tried this 3-4 times now with the same result, and have gone back to liquid lubes for my winter bikes.
So... is Putoline any better in that regard?
Posted : 06/01/2020 11:46 am
Interested to see how you get on as I'd expect candle wax to be too hard and flake off. Putoline is sticky and semi-soft, like a cross between candle wax and CV joint grease.
I do get light rust on the edges of the outer plates of the chain after I wash the bike and leave it to dry in the garage, but the lube is still well inside the chain and the drivetrain remains silent and smooth. Even when totally plastered in crud! Noise would tell me it needed re-lubing, and I get none.
I have started spraying WD40 on a rag and wiping the chain after the hose-down, see if that helps. But I don't think outer rust is important.
Posted : 06/01/2020 11:54 am
Aye the wax type are much better epically in this weather, if you can overcome your own inertia to actually apply the foul stuff in the first place!
Ive found one (the Viking Lube) that for me at least does have similar properties (no build up, clean chain, and good lube for silent running) that works at least as well.
Controversially I reckon the 12 speed cassettes suffer build up less than older 9,10 speed versions as well.
Posted : 06/01/2020 11:57 am
It really is a game changer, if you’ll excuse the phrase
Too right it is!! Buying a bloody deep fat fryer to oil a chain? What a waste! 😂😂😂😂😂
Posted : 06/01/2020 11:58 am
Another one using Peaty's Link Lube, was on Wickens and Soderstrom No3 before and it's the same stuff but with a blue dye in the waxy bit. Lasts a good 30 miles for my riding without any gunkiness, the only place it struggles is in the Beacons if it's wet where it's dead in 20. But then that soil just sucks any lube off a chain anyway, haven't found anything that lasts longer in those conditions! I just carry a tiny bottle with me and top the chain up if needed.
Posted : 06/01/2020 12:02 pm
That's taking it out of context. The point you missed was that a lube that lasts to the end of (almost) every ride*, is much better than one that occasionally lasts 5 minutes leaving the chain bare for most of the time. And that >1 ride and ~3months can and do mean the same thing, it'll often last for months, until you go out for a long ride on a really bad day.
It will last three months of weekly rides. On the singlespeed it lasts three months of mud over the winter (just don't clean the excess off when applying as there's nothing to gum up!)
*and bear in mind that the 'almost' is those days when you decide to try and ride the ridgeway in Febuary, or a bad 24h race when the course was just hub deep mud. We're talking the extreme end of abnormal. I'm planning a HT550 ride this year and wouldn't plan on taking chain lube unless the weather is looking bad enough to question going at all. I did 320 miles in a ride last year, including a fair amount off road, with about 12 hours of it in fairly heavy rain, and didn't need to lube the chain when I got home.
Posted : 06/01/2020 12:22 pm
And yet, here I am doing it. Why would that be? Cos it's much much better.
Fryers are £15 btw but I got mine free from the local Facebook page.
Posted : 06/01/2020 12:27 pm
I got a deep fat fryer for 7 quid from Tesco. That's cheaper than a bottle of lube.
I'm currently using paraffin wax. It's good but a little bit too brittle. May look at different additives to improve it.
Posted : 06/01/2020 12:49 pm
Anyone got a link to putoline at a decent price? I can only see it for £25
Posted : 06/01/2020 1:36 pm
That would be cheap. I paid £36 for my tin a while ago. It will last you for a decade or so
Posted : 06/01/2020 1:40 pm
And yet, here I am doing it. Why would that be? Cos it’s much much better.
Of course it is! You do it! 😂
I'm off to service the sash windows, whittle my own spoons and hunt my own lunch.
All faff, but so much better. 😂
Posted : 06/01/2020 1:41 pm
Muc-Off Dry Lube works great, shop around and it's usually on offer somewhere.
Posted : 06/01/2020 1:49 pm
Can't believe no one has recommended Rock'n'Roll Blue [Extreme] yet - excellent stuff.
Goes on easily, cures fairly quickly, no mucking around with heating wax, stays clean, good in the wet.
Posted : 06/01/2020 4:12 pm
Ultimately, in a real bog-bath you'll be wanting to give the drive chain a wash - I take mine off the bike and use the white-spirit in old milk container method.
Given that is the case, you have to balance - you want it to last fairly well - but then be able to strip it off to get the dirt out.
That's where the super oily stuff like Finish-Line wet falls down - it stays on too well.
Posted : 06/01/2020 4:15 pm
£24-£25 or so is the price it is, but you won't need to ever replace it, I was going to as it's now over a decade old, but then just cut the block in my fryer into 3, binned the bottom layer with all the crap in it, and the top layer which seemed light and greasy rather than waxy. The remaining bit will probably still do me another 10 years.
Posted : 06/01/2020 4:24 pm
ajt123
with putoline you never need to clean a chain - see that pic of my bike - thats after several muddy rides. Retreating it cleans it as well
Posted : 06/01/2020 4:34 pm
Can’t believe no one has recommended Rock’n’Roll Blue [Extreme] yet – excellent stuff.
It was my go-to for a long time but then they slightly changed the formulation, something to do with it now being able to be sent by air, and now it's not as tenacious. I've got the remains of a bottle of each and the new one smells distinctly less solventy and doesn't dry my skin out anywhere near as much (always forget to use gloves).
Posted : 06/01/2020 4:57 pm
A couple of questions for the putoline fans on here if I may.
I assume you degrease brand new chains before applying?
I could live with the faff if the benefits are there, but how are putoline users dealing with removing the chain off the bike? - my and my wife's mtb's are both 11sp and sram and kmc state that their quick links are either not reusable or limited to 3 uses max. I know they're arse covering and the links will probably last quite a few uses but I 'd rather not risk snapping chains.
I tend to use a descent wet lube this time of year but I haven't got a specific one I must have, currently on Kingud which seems good in terms of collecting gunk. But, I only apply it very lightly and often. I ususlly run the chain through a chain cleaner woth degreaser every 3 or 4 rides which works for me during shitty conditions (season may not be relevant). Putoline therefore wouldn't be too more faff for me really, I'm just not sure about regular chain removal.
Also, when reapplying do you just pop the mucky chain in the fryer? Does the boiling remove the crap?
Thanks.
Posted : 06/01/2020 5:16 pm
I did de-grease my chains before first application yes. Not sure how important it is though.
You can just pop the chain back in the fryer - it doesn't really get mucky. When I hose the bike down I put the water jet setting on the chain, it cleans out the grit, then I let it mostly dry and dunk it. Any water in there boils off like frying chips.
I have always re-used quick links all the time. I never knew SRAM links had a limited use - in fact I suspect they didn't until KMC put one on. However if you wanted to be really cautious you could remove the bottom pulley from your mech and if you are running 1x it'll just pop off whole. It'd probably save handling the chain as your fingers do still get a bit sticky with Putoline even though it's not a proper gunge-fest.
Thinking about it - quick links are easier to undo after a few times - so perhaps they are technically a bit looser. But if you think about how it would have to fail, I can't see how removal makes it any weaker in the normal way. And the only two chains I've had snap were SRAM and it wasn't at the quick link - in around 2006-7 when they changed their manufacturing process leading to a load of breakages IIRC.
Posted : 06/01/2020 5:56 pm
Muc-Off Dry Lube works great, shop around and it’s usually on offer somewhere.
I used to use it. Stayed on maybe two rides in the dry, in the wet - no chance.
I wonder how you people are defining 'works'? I mean.. your chain still goes round and your bike still goes forward, right?
Posted : 06/01/2020 6:13 pm
Not just me. I try lots of things, many are shit. Not this one though.
If you're accusing me of purchase bias, remember that TJ recommended it to me - I'm the last person on STW to admit he was right!
Posted : 06/01/2020 6:15 pm
same Putline tub in an Aldi £10 deep fat fryer for 3 years now and I can see no real drop in levels or why another 3+ are possible. Try it- you will not go back.
Posted : 06/01/2020 6:18 pm
“If you’re accusing me of purchase bias, remember that TJ recommended it to me – I’m the last person on STW to admit he was right!”
I have to agree that this is one of those rare occasions when TJ is right! And Molgrips too. WTAF?!!
Posted : 06/01/2020 6:23 pm
My understanding is that SRAMs limit is that links are not re-useable on another chain. You can break and re-join on the original chain as many times as you want. The prohibition means that the chain and link are worn out together, and a worn link won't then compromise a fresh chain. I'm not sure about KMC chains though, sorry.
I also have to say Putoline (and the other wax lubes) consistently come top of every comparison I've seen. I don't use them as I can't be arsed with the faff, but that's not a reason that it wouldn't work for others.
Posted : 06/01/2020 7:19 pm
I ordered some White Lightning Epic Ride off Amazon today.
Was always my favourite clean lube, but haven't been able to get it for years.
Don't tell them, but I've probably been re-using the same Sram links for five or more chains.
Haven't checked whether I'd died yet though.
Posted : 06/01/2020 7:46 pm
GT85 is the best by far, but you need to use every ride, I never clean my chains just hose any mud off and retreat with gt85 then again before I ride. I spray that stuff any place that mud goes and it just drops off. All of my riding pals use it now nothing else comes close.
Plus my drive train lasts alot longer. Try it it its cheap and smells luvvvly
Posted : 06/01/2020 10:58 pm
you could remove the bottom pulley from your mech and if you are running 1x it’ll just pop off whole
Am I being thick - wouldn't you have to saw the chainstay in two as well ?
Posted : 06/01/2020 11:14 pm
I’ve tested plenty of lubes as a mechanic and a rider in The Peak District. White Lightning clean ride is very effective even in thick mud, gritty conditions and rain. Make sure your chain is degreased and dry before use and apply to each roller. Rotate a few times, gently wipe off excess and leave overnight. The solution is best applied at room temperature (probably Californian) and shaken well between applications. However, it has surpassed expectations leaving a chain that just needs a very gentle wipe between applications and a clean cassette and chainrings. I’ve not needed to use a chain cleaner yet - it used to be after every ride! Just come back from a wet two weeks in Cumbria, no bike wash facilities and still good...Now I need to find a way to get rid of all the other lubes I’ve tested... Charity?
Posted : 06/01/2020 11:28 pm
Am I being thick – wouldn’t you have to saw the chainstay in two as well ?
Doesn't everyone ride an Orange FS on here?
No you're right. I'm being astonishingly thick!
Posted : 06/01/2020 11:56 pm
You must be deaf. Or you don't care about that loud rattling followed by actual squeaking that develops after about half an hour of riding with that stuff. I desperately wanted it to work, I tried so many times with meticulous de-greasing, but every time it just vanished long before the end of the ride, regardless of conditions. Yeah it might be clean, but that's because it's utterly devoid of lubrication, at least in my experience!
No, it washes off in minutes again. You guys must just not care about grit, wear and noise.
Posted : 06/01/2020 11:58 pm
Moley - you are begging to sound evangelical like me!
I find it incomprehensible that people pay £££ for a tiny bottle of ineffective lube when for a few £ more you can buy a kilo of a far better lube
Posted : 07/01/2020 12:46 am
Page 1 / 3
