best chain cleaner ...
[Closed] best chain cleaner / degreaser?
20 Users
Help please!
Thank you!
Posted : 23/06/2014 12:38 pm
I'm using the Green Gunk from Halfords with a cheap chain cleaner, shiny shiny!!! 8)
Posted : 23/06/2014 12:41 pm
I just use turps. Is this bad?
Having said that I've started using rock 'n' roll chain lubes recently and it keeps the chain so clean I haven't had it off the bike for ages. A good soak, firm wipe with a rag and bobs your uncle.
Posted : 23/06/2014 12:44 pm
Diesel is what I was recommended and now use after asking the same question on here.
Works like a charm and costs c.£1.35 a litre!
Posted : 23/06/2014 12:45 pm
That's a good point actually, I might start using diesel, don't know why I didn't think of that before. A lot of pro road teams used to use diesel back int day. Probably still do but with Morgan Blue branding on.
Posted : 23/06/2014 12:47 pm
[b]paraffin[/b]:- place chain in jam jar of paraffin shake leave for a while remove chain wipe ,re oil and refit.
Posted : 23/06/2014 12:57 pm
I use a mixture of petrol and four stroke oil (a little bit) in a chain cleaner because I always used this on motorbikes.
Might give diesel a go thinking about it.
Posted : 23/06/2014 2:25 pm
Is this different to the stinking diseasel that goes in my car?
A little neat Fenwicks in a chain cleaner, goes down the same drain as the rest of the bike wash water rather than storing and then disposing of old fuel.
Posted : 23/06/2014 2:31 pm
Couple of inches of petrol in a 2Litre pop bottle. Drop chain in, put lid on, shake like billio for 30 seconds, fish chain out and re-fit, re-lube with chain lube of preference. Keep the dirty petrol in the bottle for next time.
If you have a fast link in your chain the whole thing can be done in a couple of minutes.
Posted : 23/06/2014 2:40 pm
White spirit works for me.
That fenwicks squirt on mousse stuff is great.. doubles up as an after shave too
Posted : 23/06/2014 2:41 pm
 kcal
parrafin here. soak overnight or scrub, leave to dry / wipe clean.
Posted : 23/06/2014 2:44 pm
I'd prefer Fenwicks to diesel due to the fact that, as far as I know, it isn't carcinogenic.
Posted : 23/06/2014 2:46 pm
Screwfix do some cheap degreaser in a 5l container. It's been working fantastic in my JTF degreasing system!
Posted : 23/06/2014 2:51 pm
Is it?
I know diesel exhaust fumes have clear links but I didn't know that diesel as a liquid was. Could you post a link please
Ta
Posted : 23/06/2014 2:55 pm
What are you lot doing with all these lovely chemicals when you've enriched them with chain gunk?
I've been using this stuff recently (pick up from the LBS): http://www.cloverchem.co.uk/uk/products/hard_virosol_uk.htm
Works brilliantly (and I've tried a LOT of degreasers over the years) and costs half as much as most of them
Posted : 23/06/2014 3:03 pm
Petrol in a pop bottle-use it over & over, grit & gunk settles on the bottom and if it gets too much pour the petrol off the top into another bottle....or ever needed something to light that bonfire.... 😉
Posted : 24/06/2014 9:19 am
I just squirt some muc-off into my chain cleaner, used to have some proper degreaser but find this works just as well if you keep on top of it.
Posted : 24/06/2014 9:23 am
Swarfega jizer.
Posted : 24/06/2014 9:26 am
Is it?
Ta
If you're pouring/handling open containers of fuels then you'll be breathing in the vapours (both the fuel and additives are technically bad for you). [geek mode] The amount of vapour you breath in re-filling your car at the petrol station is actually higher than the recommended annual exposure limit for say your back garden if it were on nasty soils full of gunk [/geek mode].
Posted : 24/06/2014 9:30 am
I use Finish Line citrus stuff which seems pretty strong and cuts through the worst of the crap. If it's bad, it'll ho in my pot if skanky turps for a soak.
Posted : 24/06/2014 9:39 am
The best I've found so far is Viro-sol, even diluted with water about 1:1 seems to work better than proper chain cleaner stuff and a hell of a lot cheaper. Plus being a citrus degreaser I assume it is more environmentally friendly.
Posted : 24/06/2014 10:09 am
Thanks honeybadgerx for that.
I'd assumed it was the outcome of combustion that changed the risk factor of diesel rather than the fumes themselves being dangerous.
Posted : 24/06/2014 10:11 am
Sounds kinky...
Posted : 24/06/2014 10:17 am
