These are all 24 h straight-pull centerlock hubs, drop in replacements (did the spoke length calcs) from my DT350 hub which is draggy and has an awful oscillating noise, tried downgrading from 54t to 24t ratchets which only muted it (sounds like the wheel is broken).
Hope RS4 T6 alu 2-pawl 44 POE 279g €210
4 x MR17287 17x28x7mm bearings
+ sounds great
+ deep bearings
+ cheapest
+ hope customer service
+ have the hope tools
- mediocre 51 mm flange spacing
- heavy
- hard to find at the moment
Newmen Gen 2 Ratchet 20 POE 7075 alu 215g €265
4 x 17x26x5mm CN LULH bearings
+ widest 56 mm flange spacing
+ available now
+ light
- new brand, unknown resale value
- might require new tools to service
Carbon-ti X-Hub 4-pawl 56 POE 7075 Alu+Ti 181g €399
3 x 61803-2RS1 17x26x5mm + 6903RS-2RS1 17x30x5mm SKF bearing
+ wide 54mm flange spacing
+ lightest
+ SKF bearings and a large drive-side one
+ great resale value - highly regarded
- preload adjuster
- price
- maybe too loud?
Volume can be tuned with grease in most cases.
I'd have the dtswiss over any of those 🙂
Sorry, only hubs that sound good here - happy to sell the DT350 though 🙂
Has anyone suggested DT Swiss yet?
DT fanclub has already arrived yes
Flange wider = lower nds spoke tension
Good point, so I think flange width is basically a moot here.
I have DT 350's , they sound much nicer and quieter than the Hope hubs I own.
Quiet is not a sound, it's absence of sound. You can mute nearly any hub with enough grease. Plus DTs still oscillate like something is broken even with a lot of grease.
DT350 54t ratchet be warned https://streamable.com/qqrve
Old DT Swiss 240 18t hubs, very understandably packed w grease.
Shimano? Nice and quiet, doesn’t scare the wildlife!
Whether a hub sounds good or not is totally subjective so you won't ever get an answer to your question of what sounds good to you. You just need to make your own choice and get on with it.
Groan. Another thread where you ignore all the answers. I don't think it matters what hubs you fit as your never going to be happy. Why not ditch the carbon rims for something quieter or buy a wheeler from a recognised manufacturer.
Why straight pull spokes? J-bend are a lot easier to deal with.
No matter how much you tell yourself that you will get the special tool to hold your bladed spokes in place while tightening them, you will end up with them pointing in different directions.
The aero gains if you're just an old biffer like me, are negligible in comparison to the resulting irritation.
personally don't like the sound of Hope, which just goes to show it doesn't matter what other people think. If you're actually thinking of changing a hub as it sounds bad...on a road bike...that's a special category all it's own TBH.
...did the silent clutch hub ever sell ?
Whether a hub sounds good or not is totally subjective so you won’t ever get an answer to your question of what sounds good to you.
Primarily looking for something that doesn't sound broken and not one particular sound signature. Open to suggestions.
Groan. Another thread where you ignore all the answers. I don’t think it matters what hubs you fit as your never going to be happy. Why not ditch the carbon rims for something quieter or buy a wheeler from a recognised manufacturer.
No advice given, no hub suggested. Seems like there aren't that many to chose from. Choice of hubs is important so worth giving some consideration.
The aero gains if you’re just an old biffer like me, are negligible in comparison to the resulting irritation.
Once built up straight pull hubs/spokes have some advantages:
- Easier spoke replacements.
- Allows higher spoke tension (may or may not matter)
- Easier to lace.
- Better fatigue life.
- No spoke rubbing.
- Replacements are now easy to find, plus not a factor for me as I always have spares.
- The hubs don't look like they're from the 18th century.
Reusing the spokes I have so will just have to embrace the challenge - no holes in the rim bed either.
Was so pleased with my Newmen MTB wheels that I bought a second set
Question for the internet experts (because I doubt there's a good answer).
What's the point of >2 pawls?
Hope RS4 now have a 2 pawl freehub.
Hope trials free hubs were the same as normal 4-pawl free hubs, but with the pawls offset so only 2 engaged at a time, and if anyone was going to break a hub it's someone on a trials bike?
So why do hubs generally have 3 or 4 (or 6 as two lots of 3 offset). I guess more should be stronger, but presumably isn't, or isn't needed?
– Easier spoke replacements.
– Allows higher spoke tension (may or may not matter)
– Easier to lace.
– Better fatigue life.
– No spoke rubbing.
– Replacements are now easy to find, plus not a factor for me as I always have spares.
– The hubs don’t look like they’re from the 18th century.Reusing the spokes I have so will just have to embrace the challenge – no holes in the rim bed either.
Allows higher spoke tension (may or may not matter) This is based on the maximum tension allowed by the rim and not dictated by the spokes.
No spoke rubbing.??? Why will this occur. Wheel stiffness will be related to the components you use. If you use a stiffer heavier rim and heavier spokes you will get less flex from the wheel. If you think spoke tension affects stiffness then you are wrong. Wheel Stiffness
I understand everyone measures the sound a hub makes subjectively but when you start throwing crap engineering out as reasons then you should probably back off.
Onyx would solve one of your issues but they don't do a straight pull. Like most engineering problems, the solution often involves compromising some of your criterion
They look solid!
No spoke rubbing.??? Why will this occur. Wheel stiffness will be related to the components you use. If you use a stiffer heavier rim and heavier spokes you will get less flex from the wheel. If you think spoke tension affects stiffness then you are wrong. Wheel StiffnessI understand everyone measures the sound a hub makes subjectively but when you start throwing crap engineering out as reasons then you should probably back off.
Right I said may or may not matter, could matter if you have a very strong rim with few spokes? Straight pull hubs generally have stiffer flanges though.
Spoke rubbing can occur with J bend laced hubs.
Objectively straight pull hubs are a better design for two major reasons 1) easier spoke replacement 2) better fatigue life by eliminating the spoke j bend.
Personally I like j bend spokes - I’ve used them for all the wheel sets I’ve bought. They’re generally easier to get hold of spares for and are pretty easy to replace.
I’ve got Hope Pro4’s, Hunt 4 Seasons (with whatever hubs they have), some DT370’s and some no names silent things on the hybrid.
I don’t like the completely silent hubs tbh and they’re really heavy.
The 370’s sound ok - my mate thought they were loud until I got the Hope’s and then he said he struggled to think whilst I was freewheeling 😝
I think the Hunts may just be louder than the Hope’s tbh. You only have to freewheel and people almost point and stare.
I’d actually just keep the 350’s - they’re probably marginally better than the Hope alternative and will likely need less maintenance. From the video they aren’t sounding a huge amount different to the Hope’s - maybe a touch quieter I guess.
But based on all your other threads you’ll probably ignore all the advice and end up with some kind of pawl hub Novatec.
Ps. I think Newman have a good reputation for decent light / strong wheels.
I’d actually just keep the 350’s – they’re probably marginally better than the Hope alternative and will likely need less maintenance. From the video they aren’t sounding a huge amount different to the Hope’s – maybe a touch quieter I guess.
Can't you hear it's going bzzzBZZZZbzzzBZZZZ oscillating like something is broken?
Going to get the Hope RS4s if there's no better suggestion since weight isn't that important to me and they're cheaper + less obnoxious sounding than the carbon tis.
Hunt uses bitex hubs I believe.
i've got some Hope road hubs, they're far more noticeable than the DTs, somewhere between them and a Chris King in terms of high pitched bee buzzzzzzz
I'm trying to figure out what you mean by spoke rubbing? Are you confusing the issue of wheels flexing when you have a stiff rim but too few spokes, so the whole rim can twist relative to the hub and rub on the rim brake caliper?
Arguably an advantage of J-bend spokes is that they touch and therefore you can tie and solder them if you want really stiff wheels.
Generally if you want stiff you go with high flanges, straight pull hubs are probably the lowest flanges you could sensibly get.
There's a reason why track bikes use hubs like this:
Can’t you hear it’s going bzzzBZZZZbzzzBZZZZ oscillating like something is broken?
That's just the wheel being out of balance, nothing to do with the hub. There will be variations in the carbon, the tyre and, of course, there's the valve to consider.
Every SP spoke i have seen fail, fails at the head. Every J-bend i have seen fail has failed at the nipple.
So its a small sample size but seems to indicate that the bend in the spoke isnt the problem, and that it may actually be stronger than SP.
But as mentioned earlier, you do seem to ask questions and then rubbish eveyones view but your own.
I really like the wheels you bought and am now considering some myself.
That’s just the wheel being out of balance, nothing to do with the hub. There will be variations in the carbon, the tyre and, of course, there’s the valve to consider.
I balanced the wheel, no difference, and it's the same on every youtube video sound test for DT hubs.
Not nice. It's called discussing.
Make sure to get a visual inspection done beforehand. They also offer different hubs (carbon-ti's from them are only $300 for the rear for instance), there a huge farsports thread on weight weenies you could check out.
Not necessarily, DT have low relatively closely spaced flanges, Carbon ti and Hope have higher driveside flanges and wider spacing.
370 then. Otherwise there's little chance you're reusing the same spokes.
370 then. Otherwise there’s little chance you’re reusing the same spokes.
Not a bad idea (apart from the reports of their pawls being crap, so a better idea is the Hope), but only ever seen J bend 370s for sale, not sure if they even come in centerlock 24h straight pull. All the hubs listed will work with the spokes currently used according to DT's spoke length calc - or are there other reasons the spokes could not be reused? Sheldon brown thinks reusing spokes is fine https://www.sheldonbrown.com/brandt/reusing-spokes.html
I'm not that vested in the straight pull vs J bend strength discussion - of course both are fine, mostly straight pull looks better and is more practical for spoke replacements.
Close but no cigar..
The noise Hope hubs make is not a problem, it's a feature.
It tells everyone when you're slacking....
Exactly, you shouldn't be coasting anyway unless you have run out of gears going downhill so the hub noise is irrelevant. Pity you didn't get that fixed gear as you wouldn't have had this problem...
It massages your ears when you're going downhill bzzzzzzzz and can conveniently be used to let people know you're coming in a less obnoxious way than a bell. If you want to be silent you can too.
What's not to love about a reasonably loud even tick?
Thisisnotaspoon: Shimano hubs AFAIK also just have 2 pawls, seems like it's adequate and RS4 has 2 pawls for less drag and less noise whereas the Hope trials hub has 2 of its 4 pawls engage at the time to double POE from 44 to 88.
My RS4s are considerably louder than my 350s.
Loud is ok, you can tune volume with grease to some extent, but do they sound even? I.e. not oscillating a lot.
I wouldn't rely on this as a working solution. Yes for a freewheeling audio byte, but not for real world long term trouble free pawl/ratchet engagement.
Bzzzzzz Bzzzzz Bzzzzzzz ZZZZZZZZZ
Round spokes are far more aesthetically pleasing than bladed. For starters, they are symmetrical.
Having had SP-bladed spokes, and now back to round J-bends, I'm never going back.
It actually pains me to look at wheels with bladed spokes now. The physical agony is up there with the pain I used to endure when the previous hub did its uneven buzzing noise.
I can't say I give enough of a crap to notice.
I really think you need to find something else more productive to focus your energy on.
You just bought a brand new pair of wheels and you think the hub is broken so you are going to spend your own money replacing the hub??? Wtf???
You will then have miss matched hubs unless you replace the front hub.
If you think the wheel is not fit for purpose you should return them to the shop you bought them from, oh wait, you bought the cheap wheels from China.
I'd suggest before you spend another couple of hundred quid you eat some humble pie and go visit your local bike shop and ask them to take a look at them. They might spot something wrong with them, they might spot you've cocked up or they might tell you it's all in your head.
If you replace the hubs then they are no longer a cheap pair of wheels and you Could have bought some named brand from a lbs with customer service and support.
But cheap, buy twice.
Go see your lbs first! Then let us know what they say. Make sure you tell us the truth! Good luck
PS I think I'm a @yohandsome fanboi, he's the funniest thing on stw! Proper cheered me up today. His threads just keep giving. Please tell me you have a YouTube channel documenting your pursuit of speed!
Thankyou
OP - what did you use for balancing the wheels. Lead was always the "best" option but is now shunned on health grounds. Solder works well if it's small adjustments.
I too think the OP is barmy replacing the hub, and I don't have a suggestion for him, but he does know what his problem is, and neither of the statements above are true. DT hubs do make an oscillating noise - it's not caused by the wheel being out of balance. And the OP doesn't think his hub is broken - he just doesn't like the noise.
Not broken, just broken sounding :p
Could live with i that (maybe), or I could sell the old pair and get a new pair built on Hope hubs, but then I'd need to send them to China at which point Carbon-ti's would cost the same.
I’d suggest before you spend another couple of hundred quid you eat some humble pie and go visit your local bike shop and ask them to take a look at them. They might spot something wrong with them, they might spot you’ve cocked up or they might tell you it’s all in your head.
All DT ratchet hubs sound like this, design flaw I reckon, some think it's due to uneven spring tension - it's a known phenomena, but not as noticeable with lower teeth ratchets or MTB use.
I wasn't aware of this, and I didn't estimate how much deep carbon rims and road use amplified noise, so I picked the wrong hubs/ratchets, plus my bike is an only child so it needs to be perrrfect.
PS I think I’m a @yohandsome fanboi, he’s the funniest thing on stw! Proper cheered me up today. His threads just keep giving. Please tell me you have a YouTube channel documenting your pursuit of speed!
I'm putting all my free time into STW posts as is..
OP – what did you use for balancing the wheels. Lead was always the “best” option but is now shunned on health grounds. Solder works well if it’s small adjustments.
Lead golf weights about 3 grams each taped to the inside of the rim, what's the health concern?
Kudos OP, you're making my crusade against noisy disc brakes look somewhat rational! 😁
Ah, it all makes sense now. Golf...
Kudos OP, you’re making my crusade against noisy disc brakes look somewhat rational! 😁
Started my own crusade here https://singletrackmag.com/forum/topic/sram-centerline-xr-rotors-with-shimano-105-road-calipers/ - rumors has it Swisstop's Exotherm 2 organic pads are the best..(see how Shimano's 1/3 of the price organic ones do first).
Given that "broken" is a subjective values judgement in the OPs head and concerns a noise that DT hubs make (both my sets do this) it is clear he has bought the wrong hubs and wasted his money.
The chances of buying a hub that meets your brain's requirements and has same flange height is surely slim.
What made you want a noisy ratchet hub in the first place?
Chris King hubs make a right racket, but maybe it will not be a broken noise in your head?
YMMV but I had never heard an oscillating hub before and to me it sounds like it's broken. I don't think it's a weird requirement, I think it's weirder to think it sounds good.
I wasn't aware how much road use+carbon rims amplified noise coming from Hope Pro 2 Evos which sound lovely. Less is more on the road, so skeptical to both Chris King and Carbon Ti hubs with their high POE, Hope RS4 seems like a better bet.
The chances of buying a hub that meets your brain’s requirements and has same flange height is surely slim.
According to DT's spoke length calc all the hubs I'm considering are within 1 mm of the spoke length used with the DT350, so besides the rebuild cost/time it needn't be that expensive.
I hear an oscillation on that video.
100%.
Imagine going through all this, to put in a pawl'd hub that does exactly the same.
All hubs sound like that when you spin them up in your house. But you carry on...
True, but it's nowhere near as bad! Let me remind you:
DT350
All hubs sound like that when you spin them up in your house. But you carry on…
False
Ah, right now I get it. I've spotted the problem. The DT is upside down.
...and doing that with your bike upside down will scuff your saddle and shifters.
My Superstar hub has no funny oscillating noises.
Hope Pro Evo 2 40 POE low grease
https://streamable.com/awiayy
Hope Pro Evo 2 40 POE DT grease
https://streamable.com/zixctg
DT350 24 POE
https://streamable.com/zcpi0q
DT350 54 POE
I really should stop lol, but even if the Hope hub sounds aggressive with its high POE, the sound is even relative to the DT hubs. Less POE is more for road use, likely less drag that way too.
Believe recording the sound with the bike upside down on the ground is better than clamped up as it won't rock as much BTW.
You won't get any koms freewheeling!
Record it again but this time with constant pedalling
If you pedal all the time then you won't hear it.
Save your money on a wheel rebuild and buy a new chain ring like a 58t so you will never run out.
Just think of all the koms you would get with a 58tx10?
PS how much of that noise is caused by those deep rims rather than the hub? I suspect hope will also make the noise with those rims.
With all seriousness, you are never going to be happy with them. Cut your losses now, sell them and buy another set.
I made that suggestion on page one but it was ignored. Plenty of other deep carbon rim choices if that's what the OP really wants.
OP is the noise an echo? Is there anyway to fill the rim void (like vibracore rims) to reduce the echo.
The rim amplifies the noise, but it doesn't create its oscillating nature - just look at other DT hub noise vids.
Right now it's tolerable with a 24T ratchet, but it doesn't please my ears either ;p
Haha, it's just noise, let it go, ride your bike, DT hubs oscillate, accept that and deal with it or change them. FWIW Hope hubs are louder, I have both. Oh and never buy a Shimano Microspline hub for your mtb, they go between clicky and silent dependent on speed, would drive you mad!
oldnpastit
This is your second post on this thread confusing "straight pull " with "bladed" - they're not the same thing. Plenty of non-bladed straight pull spokes out there, and there are j-bend bladed spokes also.
For lower drag, go for fewer points of engagement.
I would suggest just getting used to the noise. If you're really worried about drag, as others have said, don't freewheel.
You would probably get faster from riding the thing, even if indoors on a trainer, than constantly obsessing over things that, in the real world, don't matter.
I read this and thought, this sounds like the op needs a fixed gear hub. Losing the freewheel is the only way to get rid of freewheel noise completely.
But then I thought any chain noise and bottom bracket squeaks might still bother him so maybe a penny farthing would be better.
Then it hit me. No child has ever complained that their balance bike was too loud.
The op can convert his bike to a balance bike at no expense by simply removing the drive train components and lowering the saddle. He doesn't even need to change the hub as the free hub won't rotate without the chain fitted.
Once he has ridden it in public a few times, marvelled at the silence and been sufficiently ridiculed he will hopefully realise that the free hub noise really wasn't that bad.
(Disclaimer: Some people are highly tolerant to ridicule as proven by the existence of mamils, so this approach may not work in all cases.)
Seriously OP. Just ride your bike. No bike is ever totally silent.
Appreciate the warning!
If you’re really worried about drag
Nah, but given the choice..
I read this
No you didn't.
£250 well spent 😳
Nice.
£250 well spent 😳
£161 factoring in selling the old hub, plus shaves off a bit of weight not that it matters but hey.
It's a bit loud, but not too bad and can turn the volume down by adding a bit more grease, thank lord it doesn't have the oscillating buzz of the DT.
