Best 10mm bolt thro...
[Closed] Best 10mm bolt through axle?
5 Users
Is there anything better/stiffer than the superstar QR?
Posted : 24/10/2011 10:34 am
Those DT Swiss jobbies?
Hope hubs? The there 10mm Bolt "up" conversions for Pro II's.
Posted : 24/10/2011 10:37 am
I like my 10mm DT RWS, does stiffen up the back end, never had any problems with it, had it for years.
Posted : 24/10/2011 10:39 am
Very happy with my superstar one on my saint hub, can't be beaten for value certainly.
I've heard mixed things about the bolt up versions of the ProII. The idea of a solid through axle sounds more solid to me.
Posted : 24/10/2011 10:49 am
Why? What have you heard about the bolt up versions?
Though I preface this with, I have no particular issue with either system & I use both.
BUT My front Specialized 9mm bolt thru QR (same as the SSC one) has come undone enough times that I check it regularly, this has never happened with my bolt up rear hub
Posted : 24/10/2011 11:25 am
I have a superstar one, it was cheap and does the job but started getting very stiff / corroded after about a month.
Switched to a hadley bolt which is much lighter and can be done up tighter than a QR.
Posted : 24/10/2011 11:41 am
Just read a few things about the bolt in ones coming loose.
Posted : 24/10/2011 12:28 pm
as my experince suggest.. I think it more likely to be the other way round.
+1 to the "done up tighter" comment.
Posted : 24/10/2011 12:30 pm
Where can you get these Hadley bolts from?
Posted : 24/10/2011 12:47 pm
http://www.balleracing.com/Hadley/Hadley10mmAxle.htm
If you email them and ask for the cheapest postage option it will be cheaper than the online system. For me it arrived in less than a week.
Posted : 25/10/2011 2:34 pm
