Bent Alu frame. Bin...
[Closed] Bent Alu frame. Bin or repairable?
9 Users
Hiya - My eldest son has bent the gear hanger bit of his frame. It's a cheap thing where the mech attaches direct to the frame rather than via a separate mech. I think bending it back will weaken/crack it.. is it repairable, or time to find a replacement?
Thanks!
Posted : 04/06/2020 2:18 pm
I've successfully straightened an alu hanger before, but it wasn't badly bent in the first place. Only one way to find out! I'm guessing some application of heat might help.
Posted : 04/06/2020 2:22 pm
If it doesn't straighten well you might get away with an emergency mech hanger.
Posted : 04/06/2020 3:04 pm
it'll either snap/crack when you straighten it, or it'll stay good until the next time it takes a hit
Posted : 04/06/2020 3:13 pm
Maybe get a spare just in case...
Posted : 04/06/2020 3:17 pm
Spare frame? (It's not a replaceable dropout according to the OP).
Might as well try to straighten it. If it's not rideable, you've nothing a lot to lose really.
Posted : 04/06/2020 3:29 pm
Its best to try and correct it in one slow movement rather than lots of little adjustments. Perfect excuse to buy a hanger alignment tool.
Posted : 04/06/2020 3:57 pm
if its only a small bend then just bend it back. If its a lot then heat it first. alloy IIRC tends to work harden so the actually bent bit gets harder and more brittle and heating this counteracts it.
I'd certainly have a go
Posted : 04/06/2020 5:59 pm
Nothing to lose
Posted : 04/06/2020 8:28 pm
