Bedding in Shimano ...
[Closed] Bedding in Shimano brakes
2 Users
Popping out soon to a nearby hill to bed the brakes in.
Will do a few hard stops from speed then ride up again and repeat.
Should you cool down with water bottle as Hopes used to recommend you do,no harm I guess?
Posted : 30/07/2017 1:29 pm
Should work ok. I also suggest a few more gentle stops first with aome water on the discs to transfer a bit of pad to them, like you'd use TCut then polish it off.
Posted : 30/07/2017 1:42 pm
Righto will try that too cheers
Posted : 30/07/2017 1:59 pm
