Bearings (weird siz...
[Closed] Bearings (weird size.. as always)
5 Users
Just pulled apart my E-18 PF30 bottom bracket, to see if I can replace the bearings... and need a 31x41x7mm (inner/outer/width) bearing.
Anyone deal with a bearing supplier (or got an engineer book on bearings) and know if it's possible to get any?
I've check the simplebearing website and they say NO! Obviously...
I could get a 30x41x7mm, which would sit directly onto the crankset shaft, but would prefer to avoid this...
Posted : 10/05/2013 2:34 pm
Is there a bearing number on the seal?
Posted : 10/05/2013 2:48 pm
If I wanted a weird bearing i'd go to a weird bearing seller. We used to have one here.
Posted : 10/05/2013 2:54 pm
try searching the enduro forkseals web site
Posted : 10/05/2013 2:55 pm
njee the internals & seal are tiny, just fitted a new BB and popped the top hat, couldn't see a bearing number on the new one let alone the dirt encrusted old un.
Hmm I've bought off kaesae, so may send him a mail, cheers for the idea chaps.
Have to say, considering the side of the BB30 you'd assume they'd use a bigger more robust bearing that HT II, this is more unsubstantial if anything..
Posted : 10/05/2013 3:13 pm
31 42 7 ?
6806
Posted : 10/05/2013 3:25 pm
