Bearings sizes for ...
Bearings sizes for LaPierre Zesty 327 AM 2015/2016
4 Users
 tx3m
Hello fellow riders,
I wanted to change the pivot bearings of the above mentioned bike, but somehow I am failing to find any reliable information on what sizes those should be. I am also not able to find a bearing kit for this bike, which is a bit odd.
I have also contacted LaPierre about a week ago, but so far I have not received an answer.
Has some of you already done this procedure, and can tell me what sizes bearings I need to get? Or perhaps where I could order them online?
Thanks for the help in advance 🙂
Posted : 07/05/2022 4:06 pm
Have you tried emailing support@raleigh.co.uk? I had to contact them about an issue and the help I received was speedy and really helpful.
Posted : 07/05/2022 5:24 pm
Exploded diagrams for Lapierres here.
https://raleigh.zendesk.com/hc/en-us/sections/360001155777-2020
Posted : 07/05/2022 6:37 pm
Best make sure you can get the pivot axle out before spending on bearings. MrsP had a slightly earlier zesty and the main pivot was a nightmare to shift.
Posted : 07/05/2022 6:40 pm
 tx3m
Thanks a lot for your replies. The exploded diagrams were very useful and showed that I apparently have bushings at the rear triangle. And those have proven to be quite hard to find so far where I live. But at least I now know what bearings I need so I can order them and change them.
Thanks again 🙂
Posted : 25/05/2022 10:09 pm
Are you in the UK?
Quick bit of googling find these
https://www.mbcycles.co.uk/Lapierre-Spicy,Zesty-Rear-End-Bushing-kit
Posted : 25/05/2022 11:01 pm
 tx3m
So with the help of the exploded diagram, I was able to get the right size bearings and change them. It was quite a frustrating process to be fair, but it all worked out well in the end.
Thank you all for the suggestions and help.
Cheers 🙂
Posted : 26/06/2022 9:24 am
